DA Brake Booster, Prop Valve, and Master Cylinder on EG
Old Aug 4, 2005 | 07:57 AM
herde1724's Avatar
Default DA Brake Booster, Prop Valve, and Master Cylinder on EG
anyone know if they will work or not i figure non abs car to non abs car should work .......lemme know
Old Aug 4, 2005 | 08:25 PM
herde1724's Avatar
Default Re: DA Brake Booster, Prop Valve, and Master Cylinder on EG (herde1724)
anybody anybody
Old Aug 4, 2005 | 11:39 PM
EFRue57's Avatar
I believe everything works fine. I just don't remember how the lines look that attach to the master cylinder on the EG. That is the only part I would be unsure of.
Old Aug 4, 2005 | 11:53 PM
JDM_Ej's Avatar
HT Order of Merit
Community Builder
Community Influencer
Active Streak: 60 Days
Default Re: DA Brake Booster, Prop Valve, and Master Cylinder on EG (EFRue57)
Im pretty sure the DA Master Cylinder is the same as the 88-91 EX Master Cylinder which works fine, without bending/flaring lines.
turbob18si
Suspension & Brakes
Mar 1, 2007 03:22 PM
roadrunner1
19
Feb 28, 2007 07:44 PM
adrian1281
Aug 23, 2003 09:43 PM
jdm4life
Sep 22, 2002 01:34 PM
