Best oil for for RSX-S
Old Aug 4, 2005 | 07:31 AM
Blaziniflo's Avatar
Default Best oil for for RSX-S
Getting an oil change this weekend....what do you guys use?
Old Aug 4, 2005 | 07:40 AM
130R's Avatar
Default Re: Best oil for for RSX-S (Blaziniflo)
the one from honda
Old Aug 4, 2005 | 07:55 AM
k20z's Avatar
* B A N N E D *
20w50, check ur oil cap it says 5w30 synthetic is good but it may burn faster
Old Aug 4, 2005 | 10:31 AM
ScuDC5's Avatar
I use 5w30 Royal Purple synthetic
Old Aug 4, 2005 | 10:35 AM
Kenpo's Avatar
I use mobile 1 synthetic and oil filter....
Old Aug 4, 2005 | 11:59 AM
99integsr's Avatar
Default Re: (orange stunna!)
so go with 20 w 30 for oil instad of the 5 w 30??
Old Aug 4, 2005 | 02:03 PM
JDM SPEK's Avatar
Mobile 1 5W-30 Synthetic.
Old Aug 4, 2005 | 02:19 PM
130R's Avatar
Default Re: Best oil for for RSX-S (Spoon Honda)
wow ur right for once spoon honda. good job!
Old Aug 4, 2005 | 04:31 PM
JTTeG_X's Avatar
5w-30
your car will thank you if you give it fully synthetic*
mobil 1 fully syn: 5 qt = $19.00+ tax @ walmart
Old Aug 4, 2005 | 04:59 PM
DC5AM's Avatar
Mobile 1 5W30
Old Aug 4, 2005 | 08:55 PM
DC5ITR329's Avatar
Default Re: Best oil for for RSX-S (coolguy650)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by coolguy650 &raquo;</TD></TR><TR><TD CLASS="quote">Mobile 1 5W30</TD></TR></TABLE>
thats what I use. pepboys had a buy 3 get 3 free from the calender. That's like 18 with tax for 6 quarts. I bought 60 calenders
Old Aug 4, 2005 | 09:33 PM
tommycai's Avatar
Default Re: Best oil for for RSX-S (aznbo1626)
it depends on where you live. the lower the number the colder the climate the higher the number the more hot the climate.
Old Aug 4, 2005 | 11:12 PM
JTTeG_X's Avatar
Default Re: Best oil for for RSX-S (tommycai)
i agree & disagree. i would say its a matter of driving habits and what exactly was done to the car/engine/motor that makes it need xw-xx.
IE: civic ex asks for 5w-20, great for daily driving and somewhat street use. but for hardcore tracking whereas your redlining a lot, 5w-30 would be ideal.
Old Aug 4, 2005 | 11:42 PM
xD's Avatar
xD
Old Aug 5, 2005 | 07:00 AM
Blaziniflo's Avatar
Default Re: Best oil for for RSX-S (xD)
5w30 which one?
mineral oil, synthetic blend or fully synthetic?
Old Aug 5, 2005 | 07:06 AM
ekferio's Avatar
look into amsoil too, but mobil one is easier to find....5w-30 full synthetic
Old Aug 7, 2005 | 02:27 PM
nautica_t's Avatar
Default Re: (ekferio)
mobil1 5w30 for me,
Old Aug 7, 2005 | 11:09 PM
spoonfedc5's Avatar
mobil 1 5w30 synthetic
Old Aug 8, 2005 | 09:47 AM
furious94ls's Avatar
Default Re: (spoonfedc5)
Amsoil with OEM Filtech filter.
Old Aug 8, 2005 | 10:29 AM
99integsr's Avatar
what if i liv ein sactamento ca its like consistantly above 90's then, when winter hits it gets pretty cold like the 60's
Old Aug 8, 2005 | 07:00 PM
Slow EJ8's Avatar
Default Re: Best oil for for RSX-S (99integsr)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 99integsr &raquo;</TD></TR><TR><TD CLASS="quote">what if i liv ein sactamento ca its like consistantly above 90's then, when winter hits it gets pretty cold like the 60's</TD></TR></TABLE>
pretty cold = 60's lol
Old Aug 8, 2005 | 07:04 PM
Bror Jace's Avatar
60s aren't cold ... negative 60s are cold.
Mobil 1 5W-30 (PAO synthetic) will work fine in almost any climate. It starts out a touch thinner than most 5W-30s but is fairly stable even under hard use and won't thin down much in most applications assuming a reasonable drain interval of 7,000 or fewer miles, depending, depending ...
Most other mass-market synthetics are actually overpriced mineral oil. Not bad stuff per se ... but way overpriced.
However, if you change your oil & filter every 3,000 miles, you'll do fine with just about any 5W-30. My preferences run towards Chevron Supreme and Pennzoil ... both highly refined (Group II+) base oils with advanced anti-wear additive packages (including both moly & boron). These will thin out a bit in 3,000 miles, however, and should be drained soon thereafter.
In any place in California or the southern third of the United States, you could use 10W-30 instead of 5W-30. You don't need that extra thinness at start-up and the 10W-30 is a bit more shear stable than its 5W-30 brother (all things being equal).
Amsoil is pretty good (very stable) ... but it'd be even better with moly in its anti-wear aditive package. Same with "GC" the Castrol Syntec which is labeled "Made in Germany." This 0W-30 is very good ... and a world apart from domestic Syntec 0W-30.
I wouldn't use Royal Purple ... even their synthetic thins out alarmingly quick.
You can search this other forum using the letters "RSX" for lab results of used motor oil (UOAs) for interesting info on oil and evidence of wear:
http://theoildrop.server101.com/cgi/ultimatebb.cgi
My favorite 5W-30? Schaeffer Supreme 7000 synthetic (PAO) blend:
http://www.schaefferoil.com/datapdf/701.pdf
Old Aug 9, 2005 | 01:53 AM
=SnEekY-Dc5='s Avatar
royal purple really makes a different...
Old Aug 9, 2005 | 06:21 PM
Bror Jace's Avatar
Default Re: (=SnEekY-Dc5=)
"Royal Purple really makes a different ..."
Huh?
Old Aug 9, 2005 | 08:09 PM
dc5 jared's Avatar
Default Re: (Bror Jace)
use to use 5w-30 MOTUL....cant afford it these days...but my car will be back on a steady diet soon.
