need distributor help
Old Aug 4, 2005 | 06:39 AM
Adam West's Avatar
Default need distributor help
I took off all my distributor wires and now I cant remember the order.. How do I figure this out?????? The car wouldnt start, changed distributor and fuel pump. now only cranks in morning and in the evening when its hot it dosent?????????/ wtff
Old Aug 4, 2005 | 07:17 AM
DohctorVtec's Avatar
Default Re: need distributor help (Oclooc)
this is a pic of my engine hope this helps its for a dual cam engine and a single cam engine is the same but instead of 1-3-2-4 on the dizzy its 1-2-3-4 from all that I have seen hope Im right
Modified by DoctorVtec at 12:01 PM 8/4/2005
Old Aug 4, 2005 | 07:23 AM
Adam West's Avatar
Default Re: need distributor help (DoctorVtec)
mine is single but how do I now which one goes to which.. I understand your diagram but your explaination got me confused... should I wire it just like how you have it evne though its a single???????????????????
Old Aug 4, 2005 | 07:30 AM
AbitAvenger's Avatar
just try it, also should invest in a helms manual
Old Aug 4, 2005 | 08:02 AM
Default Re: (AbitAvenger)
No instead of 1-3-2-4 on the distributor do 1-2-3-4...So like this
2 4
1 3
Modified by DoctorVtec at 12:14 PM 8/4/2005
Old Aug 4, 2005 | 08:07 AM
Adam West's Avatar
Default Re: (DoctorVtec)
ok thanx a bunch and the cylinders order stays the same right 4-3-2-1????????
Old Aug 4, 2005 | 08:14 AM
Default Re: (Oclooc)
yes
warfield21
Apr 15, 2017 12:26 PM
Atomic1
Mar 17, 2010 06:17 PM
heeltoeNdro
Mar 8, 2008 06:23 PM
accordselux
Feb 20, 2006 12:25 PM
