B16a vacuum diagram
Old Aug 3, 2005 | 10:56 PM
carlosd68's Avatar
Default B16a vacuum diagram
does any body have a pic of the vacuum diagram for a second gen B16a...i know i have a vacuum issue and a diagram will be very usefull ....thanx
Old Aug 4, 2005 | 12:46 AM
JDM_Ej's Avatar
HT Order of Merit
Community Builder
Community Influencer
Active Streak: 60 Days
Default Re: B16a vacuum diagram (carlosd68)
Is this swapped? The only vaccum lines you should have are the brake booster, PVC, FPR, and possibly MAP and EVAP. Thats it.
Old Aug 4, 2005 | 03:32 PM
carlosd68's Avatar
Default Re: B16a vacuum diagram (JDM_Ej)
cause my idle is sort of messed up and seems like if its a vacuum leak and i cant find it
Old Aug 4, 2005 | 03:35 PM
HondaFanatic708's Avatar
From: San Diego, I miss Chicago, but love SD, CA, US of fuckin A
No CEL? Usually vac leaks that effect the idle will throw a code..
Old Aug 4, 2005 | 09:27 PM
carlosd68's Avatar
Default Re: B16a vacuum diagram (HondaFanatic708)
no CEL except traction control cause im using a jdm p30
90civicSiRacer
Mar 20, 2007 10:06 AM
86ludeSi
May 23, 2005 08:20 AM
JDM_SOHC
Apr 12, 2005 07:05 AM
hondaxsimike
Sep 18, 2004 03:50 PM
ImprtTuner88
Sep 24, 2003 06:51 AM
