d15b7 into a ed questions.
Old Aug 3, 2005 | 07:51 PM
e jay one's Avatar
Default d15b7 into a ed questions.
ok i just picked up this hatch and it has a non running d15b7 the wireing harness is all hacked up and its still on the obd0 ecu. my question is what harness should i use? im gonna convert it all to obd1. i still gotta get an obd1 ecu and dizzy right? im new to the pre 92 civics thanks.
Old Aug 3, 2005 | 08:41 PM
dr_latino999's Avatar
Default Re: d15b7 into a ed questions. (e jay one)
Here is what you can do, change the driver's side mount bracket, now change the distributor to that of a D16A6, and walla, you have a MPFI D15B2 that is OBD-0.
Old Aug 4, 2005 | 05:16 PM
e jay one's Avatar
Default Re: d15b7 into a ed questions. (dr_latino999)
ok the motor is allready in the car. the wire harness is all hacked up and looks like garbage. its a d15b7 not a d15b2. its a dx so isnt it dpfi? and i want to change it to obd1. right now its not getting fuel to all the cylinders so im thinking it was never converted to mpfi right?
Old Aug 4, 2005 | 05:40 PM
Ok, let me explain this out
Ideas
1) The D15B2 and the D15B7 are the same motor, except for the camshaft in the head
2) Electronically though they are different
3) D15B7 - MPFI/OBD-1
4) D15B2 - DPFI/OBD-0
5) If you take your D15B7 and switch out your OBD-1 distributor for a OBD-0 distributor, you now have a modified D15B2.
6) If you use the D16A6 Distributor, you can have the D15B7 running MPFI no problem in OBD-0.
7) If you use the D15B2 Distributor, you can have the D15B7 running as a stock replacement in your DX, all DPFI parts intact.
8) If you retain the D15B7 Distributor, you have to convert the chassis/motor to MPFI, then to OBD-1 which will require the addition of an OBD-1 ECU.
Old Aug 4, 2005 | 07:02 PM
e jay one's Avatar
ok lets say i stay obd0 is the harness in the car set up for mpfi? or will i have to convert? the chasis is not an si so im guessing its dpfi right?
Old Aug 4, 2005 | 07:15 PM
e jay one's Avatar
is there any way to identify the engine harness and the chasis harness?
Old Aug 4, 2005 | 09:27 PM
TribusRacing
Guest
Posts: n/a
yes for the plug
Old Aug 5, 2005 | 03:57 PM
e jay one's Avatar
Default Re: (TribusRacing)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by TribusRacing &raquo;</TD></TR><TR><TD CLASS="quote">yes for the plug
huh?
SlowB20z
Sep 3, 2012 06:30 PM
carracr625
Jul 10, 2009 05:38 PM
949
Jul 4, 2009 09:18 PM
bluelsvtecda9
Apr 10, 2007 09:55 AM
Norcalstoppy
Jul 13, 2002 08:02 AM
