p28 or p72???
Old Aug 3, 2005 | 07:13 PM
dtran002's Avatar
Default p28 or p72???
hey juss wondering if i should get p28 or p72 for a 95 accord with h22a???? i heard p72 work better comparin to p28, but whats better in comparin???
Old Aug 3, 2005 | 07:30 PM
Diego Dangers.'s Avatar
maps, P28 is fine. if you can find a p06 or p05, you can convert into P28s.
Old Aug 3, 2005 | 08:06 PM
momstaxi's Avatar
Default Re: p28 or p72??? (dtran002)
with a p72 though, you will be able to control the intake air bypass function...you will also have to run a knock sensor for a p72...
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by di3go &raquo;</TD></TR><TR><TD CLASS="quote">maps, P28 is fine. if you can find a p06 or p05, you can convert into P28s.</TD></TR></TABLE>
a p28 is fine, unless he is running a stock intake manifold with has iabs...
Old Aug 3, 2005 | 11:49 PM
Nick H's Avatar
New User
Default Re: p28 or p72??? (momstaxi)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by momstaxi &raquo;</TD></TR><TR><TD CLASS="quote">a p28 is fine, unless he is running a stock intake manifold with has iabs...</TD></TR></TABLE>
if he runs the p28, even without the control of the iab's, they will just stay open all the time...this means you will only lose a slight bit of power in the low end since your runner length is shortened...however, the loss of the knock sensor is sometimes a good thing...i'd go p28 just b/c it's a little less computer control and a little bit less to deal with...that's sometimes a good thing...
MOVE OVER
Sep 6, 2007 08:59 AM
.I.Need.Money.
Aug 4, 2006 12:42 AM
DrivinVtec
May 31, 2006 05:22 AM
B2FiNiTY
May 5, 2005 04:33 AM
SiR AuToBoT
Apr 13, 2005 07:41 PM
