will 96 itr suspension fit on del sol ?????
Old Aug 3, 2005 | 05:36 PM
frost_0ne's Avatar
Default will 96 itr suspension fit on del sol ?????
im pickin a 96 itr suspension up tomoro and im wondering if it will bolt right on to my del sol so if anyone has any experience with this setup it would really help thanx
Old Aug 3, 2005 | 06:16 PM
BlueIntegraBoy's Avatar
Default Re: will 96 itr suspension fit on del sol ????? (frost_0ne)
Yup, everything bolts up. Make sure you use Del Sol rear disc brake cables.
Old Aug 3, 2005 | 11:16 PM
sess's Avatar
You'll need the rear ITR LCA's... as the itr shocks will have a 'eye socket' type bottom mount...
Old Aug 3, 2005 | 11:21 PM
JDM INSPIRED's Avatar
Default Re: will 96 itr suspension fit on del sol ????? (sess)
everything would bolts up...but if your delsol didnt have rear disc brake setup...then you will need to get a 40/40 brake proportion valve...also your delsol should have a 13/16 master cylinder...you could get a 15/16 master cylinder from a 91 honda civic ex for even better braking power...everything would drop right in and you dont need to modified any brake hard lines...
Old Aug 3, 2005 | 11:48 PM
idriveadelsol7's Avatar
Default Re: will 96 itr suspension fit on del sol ????? (HELLA JDM)
um... i don't think everything bolts up. you might have to change your shocks if you run type-R suspension. i'm not sure though.
Old Aug 4, 2005 | 04:46 AM
AzntaggeR's Avatar
TSPeed Factory
Default Re: will 96 itr suspension fit on del sol ????? (idriveadelsol7)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by idriveadelsol7 &raquo;</TD></TR><TR><TD CLASS="quote">um... i don't think everything bolts up. you might have to change your shocks if you run type-R suspension. i'm not sure though.</TD></TR></TABLE>
yep, it all depends on which components from which suspension you plan on using in conjunction with eachother. for instance if you run the ITR rear lcas you will need the ITR rear shocks as well. but if you re-use your del sol LCA you can retain your del sol shocks in the rear. for the front either will work.
Old Aug 4, 2005 | 09:32 PM
frost_0ne's Avatar
thanx for the info fellow honda techers now i just have to wait for my del slow to come back from paint to mount em up
mrsean008
20
Jul 25, 2015 04:16 AM
DaveyDelSol
Jul 24, 2006 04:06 PM
707EF8
Suspension & Brakes
Jul 22, 2006 12:22 PM
slackura
May 24, 2006 03:27 PM
Del_Sol_s
Jul 22, 2005 09:24 AM
