NEED HELP ASAP! help gettin a bolt off the steering knuckle tie rod
Old Aug 3, 2005 | 04:59 PM
vg7z's Avatar
Default NEED HELP ASAP! help gettin a bolt off the steering knuckle tie rod
im doin a tranny swap and i have to finish by tmmrw to go to work i need help asap
i need help gettin this bolt off the steering knuckle assembly that goes to the tie rod.
heres a pic
i keep loosening it and it just spins doesnt loosen. i tried to tighten it then loosen it but it doesnt tighten. PLEASE HELP!
Old Aug 3, 2005 | 05:01 PM
chad's Avatar
Moderator
Default Re: NEED HELP ASAP! help gettin a bolt off the steering knuckle tie rod (vg7z)
you do not HAVE to take that off to do a tranny swap....
Old Aug 3, 2005 | 05:03 PM
JDM-97CX's Avatar
Default Re: NEED HELP ASAP! help gettin a bolt off the steering knuckle tie rod (chad)
Take a hammer and hit the top of the tie rod directly above where the bolt is. This SHOULD lock it into place.
93(Civic)EG6
Oct 22, 2007 02:16 PM
theemaddhatterr
Mar 17, 2007 04:00 PM
Burlyirishdude
Sep 22, 2005 06:33 PM
importdude2000
May 8, 2005 04:01 PM
