possible causes of running rich please
Old Aug 3, 2005 | 01:10 PM
burgerbuddy's Avatar
Default possible causes of running rich please
i have a 88 civic dx....dpfi with full exhaust and blackish grey smoke comin out da exhaust and plugs are really black...how can i fix this...please list all possible cause of this
Old Aug 3, 2005 | 02:46 PM
Magick211's Avatar
Default Re: possible causes of running rich please (burgerbuddy)
running rich
bad fuel injector
map sensor bad
vacum leak on map sensor hose
bad 02 sensor
bad fuel pressure reg
could be lots of things
Old Aug 3, 2005 | 07:45 PM
theinfamouskonrad's Avatar
Default Re: possible causes of running rich please (Magick211)
u throwing any codes?
Old Aug 3, 2005 | 07:49 PM
Magick211's Avatar
Default Re: possible causes of running rich please (konrad)
If you all running extremely rich you should check voltage at the map sensor first. shoudnt be over 1 volt during idle
Old Aug 4, 2005 | 06:30 AM
nah no codes at all it idles fine and all but one other prob i have is if its at like 750 rpm then i floor it to rev, it makes a pop and struggles a bit but after the pop it revs fine....help me out
Old Aug 6, 2005 | 08:06 AM
bumpity bump
Old Aug 6, 2005 | 06:00 PM
help me out....evening bump
Old Aug 6, 2005 | 07:43 PM
jacobforcecrx's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Magick211 &raquo;</TD></TR><TR><TD CLASS="quote">running rich
bad fuel injector
map sensor bad
bad 02 sensor
could be lots of things</TD></TR></TABLE>
Old Aug 7, 2005 | 07:58 AM
Default Re: possible causes of running rich please (jacobforcecrx)
do you think one of those in line fuel pressure regulators would help me out a bit....i kno they dont make em for dpfi but what abouth the inline ones...can i turn it down a bit
Old Aug 7, 2005 | 09:52 AM
91sihatch's Avatar
Are you sure it is running rich? Is it burning any oil or coolant? It sounds to me more like oil burning. How many miles on the engine?
Old Aug 7, 2005 | 10:53 AM
Default Re: possible causes of running rich please (91sihatch)
nah its not burnin anything...it stoped smoking today i checked all fluids and there good...101,000 on the motor...i unplugged the o2 sensor and plugged it back in while it was running yesterday and now it dosent smoke but is still sputtery when i touch the gas hard
Old Aug 7, 2005 | 05:54 PM
well i found out that the sputtering and popping was when i did my valve adjustment i guess i forgot to tighten a set of intake bolts and they came off so no air for the no.2 cylinder and my timing was off a bit so...thanx anyways guys...its nice to know i can depend on my hona tech buddies to be there when theres a prob...thanx guys
mikevar94
Mar 13, 2014 06:56 AM
hkboy87
Dec 25, 2007 01:20 PM
wiZCo
Sep 8, 2006 01:03 PM
lopez
Oct 25, 2005 04:59 AM
93c1sol
Sep 8, 2005 11:06 AM
