Suspension & Brakes Theory, alignment, spring rates....
'96 Del Sol Si Rear Sway Bar - Will it fit?
Old Aug 3, 2005 | 12:26 PM
xkwzt21's Avatar
Default '96 Del Sol Si Rear Sway Bar - Will it fit?
Will a '96 Del Sol Si Rear Sway Bar fit my '96 Civic Sedan? I have rear LCA's with the holes for the sway bar mountings. All of the hardware is from the Del Sol. Please help me out if you can.
Old Aug 9, 2005 | 11:20 PM
EK-Chris's Avatar
Default Re: '96 Del Sol Si Rear Sway Bar - Will it fit? (xkwzt21)
No to sound like a smart ***, but have you at least placed the sway bar next to where you will mount it? It should bolt right up. Most Civic parts interchange since the Del Sol and Civic share the many suspension pieces. I have Del Sol rear discs on my EK, along with an Si sway bar.
Old Aug 10, 2005 | 01:09 AM
idriveadelsol7's Avatar
i think the lower control arms (rear) on the Ek are different from the Eg chassis. check the part #'s and don't forget to check the endlinks also.
Old Aug 10, 2005 | 01:28 PM
xkwzt21's Avatar
Default Re: '96 Del Sol Si Rear Sway Bar - Will it fit? (EK-Chris)
I would put it up to the car if I had it in my possession, but I dont want to buy it if it is not going to fit. The rear LCA's are different in the Eg and EK, but are the holes located in the LCA the same distance apart in both cars.
Old Aug 14, 2005 | 04:39 PM
Seanith's Avatar
Just get a 99-00 Si rear sway bar and call it a day hah
POE
22
Apr 4, 2019 08:25 AM
apetro94
Aug 4, 2015 01:53 PM
724chris
Mar 20, 2011 06:21 PM
xkwzt21
Aug 6, 2005 07:05 PM
GS8HFL21
Suspension & Brakes
11
Mar 27, 2005 10:36 AM
