Battery being drained
Old Aug 3, 2005 | 12:09 PM
Ronin150's Avatar
Default Battery being drained
The car is a 89 crx dx with a 92 ls swap.
I fixed my no spark problem, but now when the car cranks it's killing the battery. If the cd player is on before i try and start the car it will shut the cd player off until I'm done trying to crank it. When I would spray some starter fluid in the tb it would try and start but would just go back to cranking when I stopped spraying.
Any ideas on what could be the problem? TIA
Old Aug 3, 2005 | 01:11 PM
Skinflute22's Avatar
r u gettin fuel? also check ur grounds..
Old Aug 3, 2005 | 03:38 PM
Rostr02's Avatar
Default Re: (Skinflute22)
bump
Old Aug 5, 2005 | 12:44 PM
Ronin150's Avatar
Default Re: (Rostr02)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Skinflute22 &raquo;</TD></TR><TR><TD CLASS="quote">r u gettin fuel? also check ur grounds..</TD></TR></TABLE>
It's not that I'm not getting fuel. I think that I'm not getting enough fuel, if that's possible. The fuel line where it is connected to the fuel rail was almost completely pinched off. I swapped out the fuel rail for a golden eagle one, but now I have a leaky #4 fuel injector. Going to try and fix that problem today.
Old Aug 5, 2005 | 02:26 PM
ALLMOTORCRX20's Avatar
Default Re: (Ronin150)
sounds like you have a fuel problem. If you have an aftermarket fuel rail, it probably has a whole to add a fuel pressure gauge. It would not be a bad idea to do that just to make sure you have the right pressure.
Since your car was a DX, i would double check that all the injectors are wired correctly, to be on the safe side. You might have the right pressure, but the injectors are not getting the signal to spray.
Old Aug 5, 2005 | 04:02 PM
BURGHBAYBEE's Avatar
Default Re: (ALLMOTORCRX20)
The wiring was done by rywire.com. All of the injectors are spraying. Unfortunately I don't have enough money to pick up a fuel gauge but I'll be picking one up soon. Thanks for the input. Keep them coming.
This is Ronin150 I just can't sign out of my friends screen name.
raider099
24
Jan 16, 2024 05:27 AM
turboteg7
Dec 21, 2008 11:12 AM
lsvtecna
Mar 25, 2006 06:47 PM
sh-ef
May 30, 2004 05:48 PM
