ATTN: all 05 RSX
Old Aug 3, 2005 | 11:26 AM
Civic92Turbo's Avatar
Default ATTN: all 05 RSX
its all about the susp problem that every one is having for the 2005 RSX.... i am having the same problem right now..try and get yours fixed
[Links to foreign boards removed. You need to put the information here, not send people off into space.]
Old Aug 3, 2005 | 11:52 AM
acurate's Avatar
Default Re: ATTN: all 05 RSX (Civic92Turbo)
hasn't happened to me (yet)... but good looking on the info!
Old Aug 3, 2005 | 11:53 AM
NiPBoi's Avatar
haha i cant tell if the cliking noise is frum my struts or from header knock cuz i havent got motor mounts yet...maybe i should hurry and get mm...or atleast the esmm...
Old Aug 3, 2005 | 03:11 PM
130R's Avatar
Default Re: ATTN: all 05 RSX (NiPBoi)
3200 on mine right now. so far nothing.
if i get the problem, and it persists... there are gonna be a lot of rsx goodies for sale because ill get an s2k instead.
Old Aug 5, 2005 | 07:46 AM
Blaziniflo's Avatar
haven't had it yet, and I'm at 11k
Old Aug 5, 2005 | 04:36 PM
split's Avatar
I barely have 600 miles and I have already taken my 05 to the dealer and all they did was spray white lithium grease on the spring perch... any one know of any service bullitens?
Old Aug 5, 2005 | 05:05 PM
thrty8street's Avatar
Default Re: (split)
mine has about 800 on it right now, no noises yet. thanks for the info
Old Aug 5, 2005 | 05:10 PM
squideg6's Avatar
Default Re: (thrty8street)
I had my front coil springs replaced and so far so good it has been 3 days. The dealer fixed it no problem
Old Aug 6, 2005 | 07:47 PM
130R's Avatar
Default Re: (squideg6)
well i heard it yesterday... is there a SURE fix for this? or what?
Old Aug 8, 2005 | 11:10 AM
as of right now, honda is on a recall on the 05 suspe.... my susp is on a 1 month recall
Old Aug 8, 2005 | 12:09 PM
130R's Avatar
Default Re: (Civic92Turbo)
it doesnt say anything on the nhtsa site
Old Aug 8, 2005 | 12:14 PM
ProjectJDM's Avatar
an of right now, almost 9k miles, i have not heard anything.....
Old Aug 10, 2005 | 06:34 PM
NiPBoi's Avatar
Default Re: ATTN: all 05 RSX (ProjectJDM)
so is der a recall for them because i thought the clanking noise was my header but i replaced my motor mounts wit enjo motor mounts and i still get that noise just not as much...and w0w does my car vibrate now....
Old Aug 14, 2005 | 10:01 AM
lsvtec101's Avatar
mine has 800 and does this, looking for a perm fix
Old Aug 14, 2005 | 12:15 PM
96 SOHC VTEC's Avatar
Default Re: ATTN: all 05 RSX (lsvtec101)
I've read all those before and the bottom line is there is no perminent fix right now. I called my local Acura dealer and they said there were no service bulletins for this problem at this time. Should there ever be a universal solution that I find out about I'll post about if someone doens't beat me to it.
Old Aug 14, 2005 | 08:54 PM
eg:R's Avatar
i work at Acura and we have been replaceing the front pillow upper plate from the front shocks. it have been doing the job
Old Aug 15, 2005 | 02:23 PM
lsvtec101's Avatar
acura is coming out with a perm fix in 1-2 weeks from a good source at the local acura dealer.
Old Aug 17, 2005 | 09:05 AM
Sliced Beard's Avatar
Default Re: (lsvtec101)
I am a technician at an acura dewalerchip......wh have been replacing pillow mounts and/or complete strut assemblies.....it is an easy fix and does not take very long to fix
Old Aug 17, 2005 | 09:24 AM
Default Re: (DirtySol)
let us know if they do come out with the perm fix
Old Aug 17, 2005 | 10:17 AM
I will look at acura service net right now for any service bulletins
Old Aug 17, 2005 | 10:49 AM
the only TSB that I could find at the moment that any of you may notice is a squeaky clutch pedal. The problem is a spring inside the master cylinder rubbing. The solution is to replace the clutch MC with a revised version and to silicone the clutch line insert.
I did one of these this morning and it takes a little less than an hour to replace the MC and bleed the clutch.
Old Aug 17, 2005 | 11:29 AM
NiPBoi's Avatar
did they give any sh*t to people if they replaced there springs...im just wondering cuz i got the progress springs...on mine and im not shure if that cliking noise i hear is the prob or if my cai in bouncing off something
Old Aug 17, 2005 | 03:59 PM
lsvtec101's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by DirtySol &raquo;</TD></TR><TR><TD CLASS="quote">I am a technician at an acura dewalerchip......wh have been replacing pillow mounts and/or complete strut assemblies.....it is an easy fix and does not take very long to fix</TD></TR></TABLE>
what is the problem???? i know some people with the same car and they dont have the problem. is this on all type s's or just some and why would some have problems and others dont??? you say you replace the pillow mounts and strut assemblies but arnt you replacing it with the same part??? I was told by a acura tech that they were replacing them with parts but it wasnt working and are waiting for a perm fix from acura.
Old Aug 29, 2005 | 07:33 PM
snowwaitin's Avatar
Default Re: (carbing'ed)
i have progress springs to and mine make nosie as well i just figured it was the springs any help would be great.
Old Aug 30, 2005 | 04:21 AM
Default Re: (snowwaitin)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by lsvtec101 &raquo;</TD></TR><TR><TD CLASS="quote">
to be honest with you I think the problem is the pillow mount design. They are using rubber to metal at a moving joint and when the rubber loses its lubrication they start popping when the wheel is turned. The only way that I can think of is to convert the pillow ball to a spherical bearing or to use a pillow ball similar in style to the one used on the mid 90's Mazda minivan. There are many different designs but I think the OEM verson of the Mazda is about one of the best out there for noise supression and relability.
