tranny problems???
Old Aug 3, 2005 | 09:03 AM
213374U's Avatar
0x5359-0055
Community Builder
Default tranny problems???
Let me give you the story and tell me what you think.
Driving home today, just cruising at 55 in 5th when I hit a 45 mph zone. Went to downshift into 4th and it wouldnt lock into gear. Tried 3rd.... no go. 2nd...... no go. Would'nt shift into any gear!!! Pulled over and shut the car off and it started shifting fine. Started it back up in neutral and when I went to put it in first, it wouldn't go. Turned it off, put it in first and started the car and it drove fine from there. Had the problem about 2 other times this morning.
Thing I don't get is that this is not a persistant problem. The car will be running/shifting fine and just decide to do it. After starting it back up and driving it will run fine. I'm lost
Also, there is some clicking coming from the tranny when the clutch is engaged.
Any help here is appreciated.
Old Aug 3, 2005 | 09:05 AM
213374U's Avatar
0x5359-0055
Community Builder
Default Re: tranny problems??? (Vt4cPwn35)
This is an LS/VTec with an LS tranny
Old Aug 3, 2005 | 09:26 AM
213374U's Avatar
0x5359-0055
Community Builder
nobody???
Old Aug 3, 2005 | 09:34 AM
davens's Avatar
Dude..it hasn't even been 1/2 an hour. Give it some time.
I can't say what your problem is but it sounds like you'll be pulling it out and cracking it open.
Old Aug 3, 2005 | 09:51 AM
ash.zero's Avatar
sounds like exact same prob i had.
does your clutch pedal have good pressure? if so, there's good chance that either your pressure plate is fubar or the clutch disk is worn out. in your case, it seems to point to latter since you're still running on your stock clutch?
Old Aug 3, 2005 | 09:52 AM
DaX's Avatar
DaX
Loved
Community Favorite
Sounds like your clutch isn't fully disengaging. Is your cable stretching or loose?
Old Aug 3, 2005 | 10:34 AM
213374U's Avatar
0x5359-0055
Community Builder
Default Re: (DaX)
Will check the cable but it's a street/strip clutch.
Old Aug 3, 2005 | 10:35 AM
213374U's Avatar
0x5359-0055
Community Builder
Default Re: (Vt4cPwn35)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by nusdogg &raquo;</TD></TR><TR><TD CLASS="quote">RTFM MORON!!!!!!!!!! </TD></TR></TABLE>
Oh and to you....... reported.
ek_b16
Dec 10, 2006 10:19 PM
SPOOLINmatt
Feb 10, 2006 08:44 PM
KENLUDE97
Jun 4, 2005 05:28 AM
BlueIntegraBoy
Jul 25, 2004 11:57 AM
