CRX turbo charge pipe routing, relocation of windscreen washer bottle?
Old Aug 3, 2005 | 01:50 AM
djnikko's Avatar
Default CRX turbo charge pipe routing, relocation of windscreen washer bottle?
Hi guys,
Has anyone got any tips for the relocation of the windscreen bottle? I dont care too much about the volume of the bottle, so could I either sling it all together or just cut it to decrease the capacity which will give me room for my charge pipe routing. Im sure this has been done a million times before, please can someone post some advice
Thanks
Old Aug 3, 2005 | 05:14 AM
rioninja's Avatar
Default Re: CRX turbo charge pipe routing, relocation of windscreen washer bottle? (djnikko)
I was able to fit my charge piping past the washer bottle. It wasnt easy, but there is room to do it. Just takes a lot of measuring.
Old Aug 3, 2005 | 06:03 AM
djnikko's Avatar
Default Re: CRX turbo charge pipe routing, relocation of windscreen washer bottle? (rioninja)
It didnt look possible when I had a look, i'll take the bumper off tongiht and have another look....never say never eh!
Has anyone altered the volume of the washer bottle to make things easier?
Old Aug 3, 2005 | 08:27 AM
Doodoo's Avatar
rioninja,
What size piping did you use to squeeze past it?
Old Aug 3, 2005 | 09:16 AM
rioninja's Avatar
I used 2" inside diameter, but I'm pretty sure 2 1/4 is doable.
Old Aug 4, 2005 | 12:35 AM
djnikko's Avatar
If anyone has any pics of this section of the charge piping it would be most appreciated. I had a look last night and unless I route it under the car it still seems a little tight.
Thanks
Old Aug 4, 2005 | 06:29 AM
TheBobFather's Avatar
Here is my car. Check the end of page 1. I just took the dam thing out. If i need to wash my windshield i just stop at a gas station and use the stuff they have there. Besides, you should always keep a clean EF!!!!
https://honda-tech.com/zerothread?id=1316733
Old Aug 4, 2005 | 11:35 AM
18psi sohc's Avatar
Default Re: CRX turbo charge pipe routing, relocation of windscreen washer bottle? (jnbhonda)
I have a D16 with a T3/T04e on it. I cut out a whole on the sides of the radiator to run the piping. I ran 2 1/4 from the turbo to the intercooler and 2 1/2 from the intercooler to the throttle body. I can still use my factory foglights too.
Old Aug 4, 2005 | 01:55 PM
96-EJ6 B18C's Avatar
Default Re: CRX turbo charge pipe routing, relocation of windscreen washer bottle? (18psi sohc)
I ran 2.25" piping through there, but I relocated my washer bottle to the trash can.
Old Aug 4, 2005 | 02:34 PM
ICeDoUt's Avatar
Default Re: CRX turbo charge pipe routing, relocation of windscreen washer bottle? (96-EJ6 B18C)
shave the washer nozzles and toss that washer resorvior, think of it was weight reduction
Bictorious
Feb 19, 2004 08:44 AM
-Trinitron-
Oct 3, 2003 12:25 PM
rjardy
15
Jul 24, 2003 12:16 PM
jthelman
Feb 15, 2003 11:32 PM
redteg1
Jan 23, 2002 08:51 PM
