car shuts off after after stage
Old Aug 3, 2005 | 12:55 AM
civicstar's Avatar
Default car shuts off after after stage
setup
b18c1 JGE head
B18A1 block
315cc injectors
JUN chipped p28
it ran perfectly fine for the past 8 races and nothing was going on.it just recently started happening, i ran my nitto 555r and it was hopping alot but first time i ran, first i burnt out the tires at 6000 and it was fine, then i went to stage up at 5500 and wehn i launched, it bogged as i was racing and i coudlnt finish the race, icame back to try and stage again, staged agian and after i dumped it, the car just shut off. pulled to the side and the CEL came up. didnt have enough time to check the code. i tried to start it, it cranked, but wouldnt start. gave it gas, still wouldnt start. the fuel pump and everything turned on. but it still woudlnt start. i waited 30 mins for it to cool down adn then the CEL went off and i started it and it ran fine til almost got home when i was driving and it wanted to shut off and bogged but i dumped the clutch and didnt let it stop. when i got home, i turned it off and tried to start it, it wouldnt start. tried a push start but still didnt start.
Old Aug 3, 2005 | 07:01 AM
KingOfQB's Avatar
Default Re: car shuts off after after stage (civicstar)
umm check the code
Old Aug 3, 2005 | 08:04 AM
spockeg's Avatar
Default Re: car shuts off after after stage (KingOfQB)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by KingOfQB &raquo;</TD></TR><TR><TD CLASS="quote">umm check the code</TD></TR></TABLE>
sounds like it is a ingnition problem
Old Aug 8, 2005 | 08:17 PM
civicstar's Avatar
Default Re: car shuts off after after stage (spockeg)
hmm turned out to be a grounding problem, the battery hopped and the wires were kinda messed up
Jdv_92
Nov 20, 2012 10:10 PM
PatrickGSR94
May 6, 2009 10:03 PM
Azxster
Oct 8, 2007 05:01 PM
siregcivic
Aug 13, 2005 08:48 AM
