Where to buy Rotors/Brakes online?
Old Aug 2, 2005 | 10:17 PM
InTegraLS_2001's Avatar
Default Where to buy Rotors/Brakes online?
Hey my fellow honda-tech heads, a lil while ago my integra started experiecing shaking while braking. Upon further research i believe it to be a) either my brakes going bad or b) my rotors are warped or c) Both. Where is the best/cheapest place to buy oem replacement parts or aftermarket parts. Thanks for your input.
Old Aug 2, 2005 | 10:19 PM
LowTEC SaiMike's Avatar
Default Re: Where to buy Rotors/Brakes online? (InTegraLS_2001)
my friends go to this place called http://www.groupbuycenter.com/ they are pretty cheap, you can try that out
Old Aug 2, 2005 | 10:23 PM
EMJAY's Avatar
ebay?
00IntegrAllmotoR's Avatar
HT Black OPs
Default Re: Where to buy Rotors/Brakes online? (BomBoi)
i bought mine here http://www.importrp.com
got the brembo calipers and the Goodridge SS lines.
Old Aug 2, 2005 | 10:27 PM
Thanks guys for all your input. Any more suggestions? All replies are welcomed.
Old Aug 3, 2005 | 04:41 AM
rkrone's Avatar
if the pads are really worn out, replace those first, then
if the rotors are not that bad, have them turned, this means shave off a thin layer to even it out - pepboys does this for $8 a rotor, NAPA for $12-15, - you can only do this once per rotor
if you already did that, get a set off of ebay - make sure its a name brand though, probably about $50-65 pair
Old Aug 3, 2005 | 07:57 AM
Tim2179's Avatar
eight equals equals equals D
Community Builder
Loved
Default Re: Where to buy Rotors/Brakes online? (rkrone)
"best/cheapest"
For daily driving, just get pads and rotors from Advance or Autozone - your car will stop and it will only cost you $20/rotor and $20 for the pads.
If you want OEM Acura parts online, I recommend http://www.acuraparts247.com
Old Aug 3, 2005 | 05:11 PM
Bump
Old Aug 3, 2005 | 05:16 PM
GrayT's Avatar
Rotors don't warp. They get heat spots and pad deposits on the rotor which causes the bumping effect that people assume is warpage. You can buy some race pads and equip them for a day and drive hard and easily wear off the heatspots.
Someone said you can only machine a rotor once, not true. You can machine it until they reach the Acura/Honda specified safe limit. Any shop that does brakes should have that info.
Old Aug 3, 2005 | 05:55 PM
sqad_7's Avatar
Default Re: Where to buy Rotors/Brakes online? (GrayT)
ebay has some slotted/crossed drilled rotors for cheap prices. Then you could get some hawk pads.
Old Aug 3, 2005 | 06:04 PM
iixerOii's Avatar
Default Re: Where to buy Rotors/Brakes online? (00IntegrAllmotoR)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 00IntegrAllmotoR &raquo;</TD></TR><TR><TD CLASS="quote">i bought mine here http://www.importrp.com
got the brembo calipers and the Goodridge SS lines.</TD></TR></TABLE>
This place gets a from me too. Very good prices and great customer service.
Old Aug 3, 2005 | 06:42 PM
Tweakmeister's Avatar
Autozone blanks (ie no slotting or any of that crap) are what most of the Road Racers are using - and they'll heat up rotors more than you ever will on the street.
If no local Autozone, try http://www.cobaltfriction.com for their blanks - they're the same cheap price, and the product is good
Old Aug 5, 2005 | 10:31 PM
Thanks guys. Any more suggestions? Night time Bump
Old Aug 6, 2005 | 05:37 PM
I am ten ninjas's Avatar
http://www.irotors.com
90AcuraIntegra04
Nov 8, 2005 02:42 PM
JohnnyLux
Jun 10, 2004 07:52 PM
eg64u
Mar 22, 2004 03:23 PM
ZensokuEK
13
Oct 25, 2003 01:22 PM
crxaddikt
Apr 8, 2002 03:04 PM
