FI light came on... whats the deal?
Old Aug 2, 2005 | 07:09 PM
kaptr1d's Avatar
Default FI light came on... whats the deal?
So i was riding for just under 2 hours. took a few breaks while we were riding. bike was fine. i was like 1/4 mile from my house slowin down and the FI light comes on... bikes starts stuttering and popping, light goes away. 30 seconds later it comes back on, bike stalls out.
i shut the bike all the way off, start it back up, no light, runs fine. went another 3 blocks, FI light again, bike shuts down again. again, all the way off, all the way on, starts fine. limped it into my garage...
how do i check for a code on the bike? does this sound like anything thing neone has heard of before? i just filled it up with 3 gallons of amoco ultimate, so its def not low on gas.
BTW: 2002 CBR 600 F4I, 5400miles.
Old Aug 2, 2005 | 08:09 PM
W.O.P.'s Avatar
Default Re: FI light came on... whats the deal? (kaptr1d)
its like a check engine light for bikes. check your fuel system (air box, injectors, exhaust) there might be a clog. OR maybe one of your wires is bad
Old Aug 2, 2005 | 11:01 PM
integrator43's Avatar
Default Re: FI light came on... whats the deal? (W.O.P.)
that is basically your check engine light, yes you can check it....it will give you a code, then you can troubleshoot it..... i have the manual for 929, anyone know if it is the same for F4i???
Old Aug 3, 2005 | 12:02 AM
kaptr1d's Avatar
im gonna check tomor to see if one of my battery connections is loose. i had been havin problems with that previously.
if neone knows how i check codes thatd be great.
Old Aug 3, 2005 | 03:42 PM
Default Re: (kaptr1d)
for the 929 you just jump the test connector and turn the key on. look for blinks.
you should be able to find a manual online somewhere.
Old Aug 3, 2005 | 04:10 PM
kaptr1d's Avatar
ive got the manual for the bike. wheres the test connector?
Old Aug 3, 2005 | 05:27 PM
under seat by the battery on the 929
dragginyo
Honda Motorcycles
10
May 15, 2007 04:55 PM
EKsite
Honda Motorcycles
22
Jan 29, 2006 12:09 AM
HC313
Honda Motorcycles
25
Aug 26, 2004 11:16 AM
ringgold
Aug 12, 2003 02:03 AM
