has anyone had this problem with the A/C??? what could it be?
Old Aug 2, 2005 | 05:48 PM
sparta904's Avatar
Default deleted
deleted
Old Aug 2, 2005 | 08:08 PM
Tweakmeister's Avatar
Default Re: has anyone had this problem with the A/C??? what could it be? (sparta904)
check the belt tension first.
Old Aug 2, 2005 | 11:49 PM
integragsr96's Avatar
check your engine mounts, and also check out the tranny mounts...i know it sounds crazy, but that the exact thing happen to me on my maxima..come to find out, it waas that!!!
Old Aug 3, 2005 | 12:03 AM
HomeDepotMade's Avatar
Default Re: has anyone had this problem with the A/C??? what could it be? (integragsr96)
The air conditioner may stop working because the drive belt has come off the pulley. thats my thoughts
Old Aug 3, 2005 | 05:44 PM
Sam92Teg's Avatar
When you turn the a/c on, their is an extra load on the engine, which is normally compensated with a slightly higher idle. If the idle isn't goin up, the extra load is causing your car to idle poorly and possibly stall. Also, your compressor may be on its way out causing a severe drag on the engine. Have you heard the belt squeal at all recently?
Old Aug 3, 2005 | 08:37 PM
riceball777's Avatar
i had the exact problem with my car
every time the ac was on it would stall the car because the car was not increasing the idle
well turned out it was the computer for me. my ecu was not adjusting the idel for the ac.
same thing with my power stearing before if i turned the wheel at idea the extra load from the ps pump or ac would also stall the car
i got a new ecu and it fixed everything
Old Aug 5, 2005 | 06:18 PM
jdm'dc2sc61's Avatar
my car has been doing the same lately, but i just ignore it lol
b20bFourDoorCivicLX
Aug 18, 2013 02:29 PM
1988crxdx
24
Sep 17, 2009 07:27 PM
jdm samurai
Jul 12, 2006 07:46 AM
adamC
Oct 27, 2004 09:03 PM
MyKeerInYourEar
15
Oct 6, 2004 08:18 AM
