B20 Integra- What trans?
Old Aug 2, 2005 | 02:25 PM
kmf0211's Avatar
Default B20 Integra- What trans?
Whats up guys..Ive been doing a lot of reading and research and heres what I've been contemplating.
My current set up is a B20 longblock with my stock ls tranny clutch and flywheel.
I have the opportunity to pick up a light weight flywheel, brand new exedy clutch, and a b16 tranny all for around $700. I don't do that much highway driving, just the local highways around my area and I'm so tired of my stock LS gears they are way too long.
Does anyone think a b20 block with a b16 tranny would feel decent or should I just save up more and go with a GSR tranny?
thanks for your input
Old Aug 2, 2005 | 02:32 PM
. a d a m's Avatar
Default Re: B20 Integra- What trans? (Si.hatch.92)
My friend had a B20 swapped EG with a GSR tranny . I would definitely recommend the GSR
Old Aug 2, 2005 | 03:13 PM
Rod.'s Avatar
Default Re: B20 Integra- What trans? (Sh!ttyLS)
gsr
Old Aug 2, 2005 | 03:29 PM
importdude2000's Avatar
itr/b16
Old Aug 2, 2005 | 03:36 PM
LSvtec03's Avatar
if you don't do a lot of highway driving, absolutely positively get a b16 or itr tranny. you will love it.
Old Aug 2, 2005 | 10:20 PM
kmf0211's Avatar
I think I'm gunna go with the b16. Eventually this thing will be b20/vtec but for now its just my LS replacement after i jumped timing.
I know the car will be flying through gears, but does the shorter gear ratios really make a huge difference in speed?
Old Aug 2, 2005 | 11:24 PM
LSvtec03's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Si.hatch.92 &raquo;</TD></TR><TR><TD CLASS="quote">I think I'm gunna go with the b16. Eventually this thing will be b20/vtec but for now its just my LS replacement after i jumped timing.
I know the car will be flying through gears, but does the shorter gear ratios really make a huge difference in speed?</TD></TR></TABLE>
yes. that's the point. you will accellerate a lot faster than with a crappy ls tranny.
Old Aug 3, 2005 | 02:15 PM
timisyourfriend's Avatar
Default Re: B20 Integra- What trans? (LSvtec03)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by LSvtec03 &raquo;</TD></TR><TR><TD CLASS="quote">
yes. that's the point. you will accellerate a lot faster than with a crappy ls tranny.</TD></TR></TABLE>
Not unless you're smurbo turbo!! (=
Old Aug 3, 2005 | 03:39 PM
teknoracing's Avatar
Default Re: B20 Integra- What trans? (JZPerformance)
B16 or ITR which ever you can find cheaper
Old Aug 3, 2005 | 03:43 PM
WTB AUTO EK's Avatar
Default Re: B20 Integra- What trans? (teknoracing)
i put in a B20 in my automatic LS. Using the automatic tranny, it bolted right on within a few hours. Using the LS Ecu, I was able to climb hills faster without having to downshift. So I recommend the automatic LS tranny
Old Aug 3, 2005 | 03:58 PM
GDR888's Avatar
Default Re: B20 Integra- What trans? (SayMyName)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SayMyName &raquo;</TD></TR><TR><TD CLASS="quote">i put in a B20 in my automatic LS. Using the automatic tranny, it bolted right on within a few hours. Using the LS Ecu, I was able to climb hills faster without having to downshift. So I recommend the automatic LS tranny</TD></TR></TABLE>
WHAT?
Old Aug 3, 2005 | 04:22 PM
Default Re: B20 Integra- What trans? (GDR888)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by GDR888 &raquo;</TD></TR><TR><TD CLASS="quote">
WHAT? </TD></TR></TABLE>
YEAH!!!
MY LS had a blown head gasket and I got a killer deal on B20. Since b series are compatible, I bolted it on with the help of some cool guys at honda of phx.
Old Aug 3, 2005 | 04:32 PM
kmf0211's Avatar
Thanks for your input and everything but I was specifically talking about my 5spd LS tranny vs. a 5spd B16 tranny.
My ls shredded the timing belt and had blown rings so it was time for a step up to the b20 and I love it.
Old Aug 3, 2005 | 05:51 PM
LSvtec03's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JZPerformance &raquo;</TD></TR><TR><TD CLASS="quote">Not unless you're smurbo turbo!! (=</TD></TR></TABLE>
especially if you're turbo.
Old Aug 3, 2005 | 06:21 PM
rodimus's Avatar
b16 still faster with forced induction.
Old Aug 3, 2005 | 06:46 PM
DsBananas94LS's Avatar
Stay with the LS just make more power you always want a gear w/ long tranny so you can spool ur turbo there is no need for short gear tranny just more power
Old Aug 3, 2005 | 07:25 PM
LSvtec03's Avatar
Default Re: B20 Integra- What trans? (DsBananas94LS)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by DsBananas94LS &raquo;</TD></TR><TR><TD CLASS="quote">Stay with the LS just make more power you always want a gear w/ long tranny so you can spool ur turbo there is no need for short gear tranny just more power</TD></TR></TABLE>
what's the point of even correcting people, when there will always be new people that still think this is true?
Old Aug 3, 2005 | 08:41 PM
FrOsTwHiTeDC4's Avatar
b16!!!! if your not gonna boost a b16 would be good, i think. im running a b16 on my boosted b20. the gears are a lil short for boosted but n/a it should be fine!!
Albert
DrGrEeNtHuMb
Mar 23, 2008 06:21 PM
DC4 Rasta
Apr 17, 2007 06:16 PM
crxpwr1
10
Apr 13, 2007 07:55 AM
Santys EK
Jun 14, 2005 12:17 PM
