rod & main bearing ?
Old Aug 2, 2005 | 02:23 PM
staticrex's Avatar
Default rod & main bearing ?
If either of these are going will the car make a noticable sound upon start up? I have a metallic rattling sound in the morning when I start the car up , but it goes away when the car fully warms up.
Could this be my bearings?
Old Aug 2, 2005 | 02:38 PM
BDRphaSe2's Avatar
nope, most likley the skirts on the pistons...when cold metal contracts...so their built in an egg pattern... so they rattle in the combustion chamber. when the engine heats up the metal expands... and the skirts on the pistons fill the cylinder walls up and that why u cant hear it anymore.. im 99.9% sure thats the rattling...i doubt its your bearings...
Old Aug 2, 2005 | 02:58 PM
staticrex's Avatar
Default Re: (BDRphaSe2)
Is this something I should be concerned about. should I stop driving the car and get it fixed?
Old Aug 2, 2005 | 03:24 PM
BDRphaSe2's Avatar
nope, dont worry about it at all... it doesent do anything to performance and doesnt make your engine wear abnormally. and i bet you if u took it to honda theyd say the same thing... its not as common in imports that i know of but alot in like GM models... (aka pieces of ****) lol but jsut cause urs does that doesnt mean its **** i just say GM = ****
Old Aug 2, 2005 | 05:09 PM
Chiovnidca's Avatar
Default Re: (staticrex)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by staticrex &raquo;</TD></TR><TR><TD CLASS="quote">Is this something I should be concerned about. should I stop driving the car and get it fixed?</TD></TR></TABLE>
Just drive it easy till it's warmed up.
Old Aug 3, 2005 | 06:18 AM
staticrex's Avatar
Default Re: (Chiovnidca)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Chiovnidca &raquo;</TD></TR><TR><TD CLASS="quote">
Just drive it easy till it's warmed up.</TD></TR></TABLE>
Yeah well I naturally drive the car easy, shifting before 3k when warming up and rarely shifting higher than 4k when the car is warm. Every once in a while I will open her up , but not very often.
thanks guys
Old Aug 3, 2005 | 06:04 PM
l2yanE's Avatar
It can be the valves to, if they are somewhat lose after they get hot they get tighter and shut up, I thought mine was piston slap turned out the oil pump was die'in and it took out my rods and mains
Old Aug 3, 2005 | 08:20 PM
PrecisionH23a's Avatar
Default Re: (l2yanE)
valve adjustment time.
if it were bearings the noise wouldn't go away and get louder as the rpms increase.
Jaycrv
Honda CR-V & Element
Jul 8, 2017 02:22 PM
SPOOLINmatt
Mar 14, 2006 01:01 PM
Killersohc
Nov 22, 2005 06:31 PM
b16a27
Jun 7, 2005 08:15 PM
cbrodac0424
Aug 1, 2004 08:50 AM
