Hesitant Start?
Old Aug 2, 2005 | 01:13 PM
CelicaGT-S's Avatar
Default Hesitant Start?
Ive had the rex for about 3 months....91 crx si....started up just fine but lately its been real hesitant to start, it will crank and crank then sounds like it wants to start but doesnt and then just cranks again....Whats could be the problem? Help a.s.a.p
Old Aug 2, 2005 | 02:27 PM
Magick211's Avatar
Default Re: Hesitant Start? (CelicaGT-S)
Do you hear the fuel pump prime everytime you turn the key to the on position?
Old Aug 2, 2005 | 02:31 PM
b18_crx's Avatar
Default Re: Hesitant Start? (Magick211)
CHECK DIZZY..............Spark....... fuel? on all three of my si's the dizzy has gone bad....usually coil
Old Aug 2, 2005 | 02:41 PM
CelicaGT-S's Avatar
What the heck is the dizzy....NewB to the ef's....
Old Aug 2, 2005 | 02:46 PM
CelicaGT-S's Avatar
If by prime you mean it swooshin gas, no? No noise at all? Whats the problem?
Old Aug 2, 2005 | 02:50 PM
b18_crx's Avatar
Default Re: Hesitant Start? (b18_crx)
DIZZY = DISTRIBUTOR, CHECK FUEL LINES FOR FUEL PRESSURE
Old Aug 2, 2005 | 03:07 PM
CelicaGT-S's Avatar
and how do i check the dizzy?
Old Aug 2, 2005 | 03:40 PM
Magick211's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by CelicaGT-S &raquo;</TD></TR><TR><TD CLASS="quote">If by prime you mean it swooshin gas, no? No noise at all? Whats the problem?</TD></TR></TABLE>
well you you turn the key to the on position you should hear the full pump make a humming noise for a few seconds. If its not doing that you could have a bad main relay
Old Aug 12, 2005 | 03:43 PM
CelicaGT-S's Avatar
well timing was a little off....got it timed....but it idles constantly at 300 to 1500 rpms up and down......And after i timed it it still hesitant after the 2nd or 3rd time i try to start....WHY????????Some one please help....
Old Aug 12, 2005 | 09:41 PM
CelicaGT-S's Avatar
ttt
Old Aug 12, 2005 | 10:23 PM
I3ackfire's Avatar
Check your ECU for any codes. I had this problem before and it turned out to be Injectors.
Old Aug 12, 2005 | 10:32 PM
CelicaGT-S's Avatar
Default Re: Hesitant Start? (I3ackfire)
And how exactly do i do that?
Old Aug 12, 2005 | 11:22 PM
I3ackfire's Avatar
Pull down the carpet from the firewall in your passenger side footwell, and it will be there. There will be a metal cover with the small hole in the center of it. Put your key in the ignition and just put it to the start position, without starting it, and then check that hole for flashes. Write down what you see and check back on here and we'll try to help you out!
Old Aug 13, 2005 | 04:33 AM
CelicaGT-S's Avatar
All it did was flash once when i put it in the start position...How long do i wait for?
Old Aug 13, 2005 | 11:54 AM
CelicaGT-S's Avatar
ttt
Old Aug 13, 2005 | 03:30 PM
CelicaGT-S's Avatar
Mr.Aaron
Apr 21, 2018 04:00 PM
Nooch
Dec 24, 2010 05:36 AM
alex_s817
Jul 14, 2006 04:25 PM
B18Cej1
12
Nov 8, 2005 05:05 AM
Civicboy
14
Feb 1, 2003 11:15 PM
