96 accord fender removal
Old Aug 2, 2005 | 09:41 AM
jchandler's Avatar
Default 96 accord fender removal
I'm having trouble removing the front passenger side fender. I've got all the bolts out except for the lower bolt near the door. It is blocked by the plastic trim piece that runs along the bottom. How do I remove that piece. It is held by several plastic retainers/screws. I removed those but it still won't come out. Are there more retainers to remove? I can't get to the last fender bolt without getting this trim piece out of the way. Please help.
Old Aug 2, 2005 | 10:16 AM
devilpuppy's Avatar
Default Re: 96 accord fender removal (jchandler)
the stock side skirt....you have to take out all the clips and tug the skirt either to the left or right, i can't remmeber which way and then the skirt will come off....you cannot pull the skirt straight off
it has to be pulled to one side...the it will come out
Old Aug 2, 2005 | 10:54 AM
i20ar's Avatar
i belive there is one bolt under where your intake is.. its located right under the lip i think its 10mm that
Old Aug 2, 2005 | 11:20 AM
Kwisatz Haderach's Avatar
I'll give you the same advice I got when I started my job at a body shop. Look. If its not coming off, then look harder, theres always a way. Maybe have a friend look at it, someone with fresh set of eyes.
Old Aug 2, 2005 | 12:02 PM
jchandler's Avatar
Default Re: 96 accord fender removal (Dj14aZnS)
That makes sense. I was trying to pull it straight out. I'll try it your way. Many thanks.
Old Aug 2, 2005 | 06:11 PM
momstaxi's Avatar
Default Re: 96 accord fender removal (devilpuppy)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by devilpuppy &raquo;</TD></TR><TR><TD CLASS="quote">the stock side skirt....you have to take out all the clips and tug the skirt either to the left or right, i can't remmeber which way and then the skirt will come off....you cannot pull the skirt straight off
it has to be pulled to one side...the it will come out</TD></TR></TABLE>
yes, it will slide towards the front of the car then off...
Pauly321
Jul 30, 2009 05:41 PM
R1C3Rxs
Apr 22, 2008 02:36 PM
3lo
Apr 6, 2008 09:57 AM
4 door GSR
Jan 13, 2008 06:00 PM
Isaac
Sep 9, 2001 05:28 AM
