94 integra died while driving
Old Aug 2, 2005 | 09:14 AM
94redintegra's Avatar
Default 94 integra died while driving
two days ago i was cruising at about 80mph, all the sudden it just died, so i put it in neutral and started it back up, it started just fine so i just kept driving, later that day it was parked i started it up put it in first gear and started to go it died agian, so i put it in neutral started it back up and kept driving, two days go buy and it does the same thing, let it sit over night and the next day i went to start it, it would kick over then die it did this about 5 times then kicked over and started driving, any one have any ideas, about 15k miles ago i had a new fuel filter put on, spark plugs and wires it runs like its brand new, but has 170k on the clock
Old Aug 2, 2005 | 09:20 AM
UNDERGROUNDAUTOSALON's Avatar
Default Re: 94 integra died while driving (94redintegra)
when this happens check for spark, if no spark test your coil & ignitor.
if you have spark check your fuel, possible main relay if its been happening when its real hot I would change it out for a new one (not used). then check the fuel pump. they are the real common easily fixed things.
Old Aug 2, 2005 | 09:36 AM
Default Re: 94 integra died while driving (UNDERGROUNDAUTOSALON)
its hard to check for spark because when this happens it just starts back up right away
Mugencrxsir1
Oct 9, 2011 12:15 PM
ef roni
Nov 12, 2008 10:34 PM
TheTealHatch
13
Oct 15, 2008 04:02 AM
Meesterzoomak
Jan 25, 2007 04:25 AM
Master23
Aug 1, 2004 08:16 PM
