Trouble Starting at times recently?
Hey guys... Recently for some reason I'm having trouble starting my Ls/Vtec turbo... All summer it started the first time every time and when it does start it runs perfectly... But the past month or so it doesn't start at times... Just cranks over and over with no kick over...
I just cleaned and check the spark plugs. I can smell fuel, but what should I check next? Again the engine turns over and over... If I let it sit for 2 hours and come back it usually starts right up?
Makes no sense I'm left scratching my head... This is not a daily driver, just my weekend crx...
Any thoughts insights would be awesome!
Thanks
Thanks
Re: Trouble Starting at times recently?
Could it be time for new spark plugs? I have older Denso Iradium plugs 7 heat range or possibly plug wires? But again once the car starts it runs perfectly! So I'm confused...
When it doesn't start you need to check and make sure you have fuel pressure and spark.
Sounds like you are having some intermittent problem, but you need to narrow it to either fuel or spark.
And no this will be my second winter with this engine set up... Everything was dyno tuned last December...
Thanks for the input guys, keep them coming!
After work today I'm heading over to Advanced to pick up some new Denso plugs... I have a feeling this will do the trick, if not I'll be back here with more questions! LOL
Thanks,
Thanks,
Yup it was the spark plugs... Just replaced them with new Denso's and it starts right up!
Thanks fellas!
Thanks fellas!
tpot90
02-12-2008 12:00 PM
quad
20
03-14-2007 05:16 AM
