FS in CO: 457 whp, daily driven '95 Civic Sedan
Old Aug 2, 2005 | 06:02 AM
westcoaststyle's Avatar
Default FS in CO: 457 whp, daily driven '95 Civic Sedan
<FONT SIZE="4"><FONT COLOR="red">SOLD BITCHES!</FONT></FONT>
<FONT COLOR="red">THE PRICE ON THE CAR HAS RECENTLY BEEN LOWERED - PM/EMAIL FOR DETAILS
THIS SALE IS FOR SERIOUS BUYERS ONLY - IF YOU DO NOT THINK YOU CAN AFFORD THIS CAR OR ARE JUST CURIOUS ABOUT IT, MOVE ALONG. I WILL ONLY ENTERTAIN SERIOUS INQUIRIES!</FONT>
Videos:
374 WHP dyno run: http://www.savefile.com/fileho...60148 (updated)
13.36 1/4 run in 2002: http://www.savefile.com/files/4526052 (strong language)
Images:
**** PICS TAKEN & ADDED 7-11-2005 ****
Mods are as follows:
Engine Modifications:
Block
- B18C1 Swap
- AEBS T-Sleeves installed by AEBS
- Cylinders bored to 84mm
- Custom ROSS 84mm 9.5:1 pistons
- Pauter I-Beam Rods
- ARP rod bolts
- AEBS main studs
- ACL main bearings/rod bearings/thrust washers
- Balanced & blueprinted crank, rods, pistons, flywheel, clutch, and crank pulley
- Full new conversion kit (bottom end gasket set - Summit Racing)
- Energy Suspension and Prothane motor mount inserts
- Hyper ground wire kit
- Custom 2.5" exhaust to Random Tech 2.5" CAT to an Apexi N1 muffler
- DC Sports battery tie-down (polished)
Head
- Port matched on the intake side
- Port matched on the exhaust side
- 3 angle valve job
- Decked
- AEBS Head studs & nuts
- Acid dipped & glass bead blasted head
- All new head gasket/seal set (OEM Honda)
- Cometic 84mm head gasket
- JDM ITR red valve cover
- Skunk2 polished intake manifold port matched to head
- Hondata intake gasket
- Carbon fiber wire cover
- Magnacor 10mm plug wires (red)
- MSD Blaster external coil w/ distributor cap
- NGK-R spark plugs
- AEBS cam seal
- OEM JDM ITR cams
- AEM 5-bolt cam gears
- Supertech titanium retainers
- Rocket Motorsports Gen1 valve springs
Fuel
- AEM fuel rail (red)
- AEM high flow fuel filter (silver)
- RC 650cc injectors
- AEM adjustable fpr
- B&M fuel pressure gauge
- Walbro 255 LPH HP fuel pump
Cooling
- GSR OEM radiator retrofitted w/ custom mounts
- FAL Civic fan fitted onto the GSR radiator w/ custom mounts
Drivetrain
- OEM GSR Transmission
- OEM axles
- ACT XTR6 clutch/pressure plate
- Energy Suspension shift linkage bushings
- Skunk2 dual-bend short shifter
- Clutchmasters 7.5lb flywheel
Turbo
- MaxRev kit
- MaxRev shorty manifold - polished
- MaxRev 2.5" downpipe
- Garrett T3/T04E 57 trim .60 A/R turbo
- TiAL 35mm wastegate w/ .75 BAR 'big yellow' spring
- HKS SSQ BOV
- Greddy Type 24 FMIC
- Greddy Full Auto turbo timer
- Greddy Profec-B Spec-II boost controller
- Custom 2.5" intercooler piping
- Apexi Power Intake filter
- Hondata 3BAR MAP sensor
Engine Management
- OBD1 P72 ECU
- Hondata S200B w/ datalogging and 3step rev limiter (soon to be Neptune)
Dyno Results & 1/4 Mile Times
- 457 whp / ~370 wtq @ 22.5psi @ 8000 ft elevation - Dyno Sheet
- 12.607 @ 114.86 @ 12.6psi on street tires (Falken Ziex) - Timeslip 1 - Best Time Yet / Timeslip 2 - VS a WS6
Suspension & Brake Modifications:
- Koni Yellows
- Skunk2 coil-overs
- Neuspeed front-upper strut tower brace
- Energy Suspension full bushing kit
- Brembo blanks (stock replacements)
- Nissin brake pads
- GSR rear LCAs
- ITR rear sway bar w/ custom fit Beaks mount kit & Prothane bushings
- GSR front LCAs
- GSR front sway bar w/ Energy Suspension bushings
- GSR Master Cylinder and Brake Booster
- 1993 Integra LS nonABS proportioning valve
- Full front and rear GSR disc brake upgrade
- Earl's stainless steel brake lines
- Axxis Ultimate brake pads (F)
- Axxis Metal Masher brake pads (R)
- Rota 16x7" Slipstreams in gunmetal with a polished lip (13.5 lbs/ea)
- Falken Ziex 205/45/16's
- 2 Konig 15x6.5" Heliums in bronze (11 lbs/ea - used only for drag racing)
- 2 BF Goodridge T/A Drag Radials 205/55/15
- Kyokugen JDM keyed Gunmetal lug nuts
- Omnipower front-upper A-arms w/ camber adjusters
- Ingalls rear camber adjusters
Exterior Modifications:
- JDM EG9 headlights w/ Raybrig H4h bulbs & PIAA Xtreme white city lights --- The city lights are wired as they are wired in Japan. When the parking lights are turned on only the city lights illuminate with the tail lights. The corners only illuminate when the turn signal is engaged.
- JDM EG9 clear corners
- JDM EG9 sidemarkers
- Red/clear taillights
- ABS Mugen replica front lip
- EK side skirts
- ABS CTR replica rear lip
- TC Sportline OEM-look carbon fiber hood
- JDM EG9 Ferio sail covers
- JDM EG9 Ferio trunk lid
- JDM EG9 Ferio rear spoiler
- JDM EG9 Ferio rear trunk emblem
- JDM rear Civic emblem
- JDM rear SiR emblem
Interior Modifications:
- JDM clock
- JDM climate control face and orange backlighting
- JDM coin pocket
- GSR gauge cluster w/ orange backlighting
- ITR style shift ****
- OEM optional armrest
- Greddy EGT gauge
- Autometer Z-series oil pressure gauge
- Paintmatched 2 gauge pillar pod
System:
- Sony eXplod 50x4 dual face head unit
- MB Quart component set / 6" mids & 1" tweeter
- Polk Audio 6.5" coaxials in the rear
Alarm:
- Blackwidow with keyfob pager
Photo Galleries:
Exterior: http://www.honda-acura.net/for...61485
Engine (rebuild in progress): http://www.honda-acura.net/for...42746
http://s115824406.onlinehome.u...2.jpg
http://s115824406.onlinehome.u...d.jpg
http://www.honda-acura.net/for...stc=1
Pretty recent (exterior): http://www.honda-acura.net/for...83245
Latest parts: http://www.honda-acura.net/for...88670
Dyno info: http://www.honda-acura.net/for...90339
My HAN Garage: http://www.honda-acura.net/for...=1197
ITEMS INCLUDED IN SALE:
• Everything listed above
• 1998 Integra LS manual tranny
• 2 15x6 Konig Heliums (12 lbs/ea) w/ great condition BF Drag Radial 205/55/15
• Honda OE leather full front bumper cover (bra)
• Honda OE leather front hood cover
• Brand new brake master cylinder (installed)
• Brand new Falken Ziex 215/40/16 tires (w rated)
• Integra GSR gauge cluster (car is wired)
• Civic EX gauge cluster w/ carbon fiber gauge bezel (car is wired)
• Full set of OEM rims for snow tire use
This car was the Honda-Acura.net February 2004 Featured Ride
I have receipts for almost everything that is currently installed on the car and any mod/admin on Honda-Acura.net or those listed in my feedbacks can vouch for me and this car. I can provide any information you need and pics of anything as well. This is a nasty car (power-wise) and reliable as a daily driver. There are about 110,000 miles on it, but the interior and body are really the only parts that are not new. The body has minor wear and tear blemishes, as does the interior (no holes or cig burns). The car has never been smoked in and I am the second owner.
My thoughts toward the sale price of this car is pretty much up in the air. I know I have around $30k into the car, but... it's a Civic so I don't have any delusions of grandeur. The blue book value of the car is apprx. $4,000. Don't offer me this or I will laugh at you and you will feel stupid. h:
I have modded this car with a 'non destructive' mentality so there are not unused holes anywhere on the car. The engine wiring has been done with care and precision as has the rest of the mods. I am a perfectionist so you can be assured that the car is in great condition.
Please email me at curtisaj@adelphia.net for the fastest response. I am willing to be as accommodating as possible to long-distance buyers so do not let that limit you.
Thanks, and please bump this often.
Josh
Modified by westcoaststyle at 7:08 PM 7/11/2005
Modified by westcoaststyle at 1:31 PM 8/1/2005
Modified by westcoaststyle at 8:22 PM 8/1/2005
Modified by westcoaststyle at 8:46 PM 8/1/2005
Modified by westcoaststyle at 8:18 AM 8/2/2005
Modified by westcoaststyle at 6:12 PM 8/3/2005
Modified by westcoaststyle at 7:20 PM 9/6/2005
Old Aug 2, 2005 | 06:05 PM
freaker's Avatar
Default Re: FS in CO: 457 whp, daily driven '95 Civic Sedan (westcoaststyle)
Wow nice! This would haul my family nicely.
Old Aug 2, 2005 | 07:08 PM
Wanna buy it?
Old Aug 3, 2005 | 06:39 AM
Hump day ^
Old Aug 3, 2005 | 10:52 AM
freaker's Avatar
Default Re: (westcoaststyle)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by westcoaststyle &raquo;</TD></TR><TR><TD CLASS="quote">Wanna buy it?</TD></TR></TABLE>
I ******* wish. I would love to own it. Just for grins pm a # on what you want for it.
Old Aug 3, 2005 | 05:14 PM
First video updated, I think it may have been corrupt
Old Aug 4, 2005 | 05:46 AM
Movin' on up ^
Old Aug 4, 2005 | 12:17 PM
Tomorrow's Friday
Old Aug 4, 2005 | 04:31 PM
JoKarma's Avatar
You know, I have a video of your car from last year. Tearing down a highway or something doing a buck twenty?
This was like the first proof I can remember that sedan can be badass. Why are you selling it again?
Major props and a bump.
Old Aug 4, 2005 | 04:52 PM
lol, I still have that.
I've had it for quite a while and I just need a chance. I've had my eye on an IS300 for years now and that's what I think I will get. Thanks for the props and bump.
Old Aug 4, 2005 | 06:58 PM
JoKarma's Avatar
Ill make a quarter of your IS payments for it?
heh, hey. Im going to pm you a couple questions tomorrow
Old Aug 4, 2005 | 07:05 PM
I'd rather get the money up front for a down payment.
I'll be around for the IM.
Old Aug 5, 2005 | 08:29 AM
w00t Friday again
Old Aug 6, 2005 | 01:04 PM
civicboisi's Avatar
my god!
Old Aug 6, 2005 | 03:52 PM
Default Re:
Old Aug 10, 2005 | 11:32 AM
JoKarma's Avatar
Default Re: Re: (westcoaststyle)
bump
Old Aug 10, 2005 | 10:17 PM
stewmaster-k's Avatar
Default Re: Re: (JoKarma)
bump for a nice *** car
Old Aug 11, 2005 | 09:31 PM
Default Re: Re: (stewmasterk)
bump to help u sell a nice car
Old Aug 19, 2005 | 06:38 AM
still fs ^^
Old Aug 23, 2005 | 06:24 AM
^ up up up ^
Old Aug 24, 2005 | 10:27 AM
^ to the top ^
Old Aug 24, 2005 | 04:26 PM
Old Aug 25, 2005 | 07:10 AM
%% bump %%
Old Aug 25, 2005 | 09:30 AM
egizzle8
Guest
Posts: n/a
That car is like a spitting image to my 4dr right down to the same cd deck! lol. I had to take a double take. I just have the Ferio interior and a turbo'd LS. Big on a sweet ride.
Old Aug 25, 2005 | 10:12 AM
Hahah
