GSRLS-Vtec Build
Old Aug 2, 2005 | 05:50 AM
Natural Aspirations's Avatar
Default GSRLS-Vtec Build
This is not for a daily driver but does need to be streetable
I would like some opinions on my ls/vtec build.
I have 90% of these parts just waiting on the last few items to assemble
Compression will be in the low 13's
Pistons are Wiseco with a 8.25cc dome
Eagle rods 3/8 bolt
00 B16a2 Head
Omni Valves - (Need)
Blox Intake Manifold
Max Bore Gsr Throttle Body - (Need to send)
RC 270cc Injectors
99 GSR Block
Eagle Oil Squirter Plugs
ARP main Studs
ARP Head Studs
CTR N1 pulley (no comments necessary)
LS Crank1
Old School AEM cam Gears
Rocket Motorsport 22x Cam and Valvetrain Set - (Need $$$$)
Header - (On the List for an RMF Narrow) 2 weeks to go
Head Porter - (looking into the possibility of one of the cnc shops)
Ys1 GSR Trans
ClutchMasters stage 3 Clutch
ClutchMasters 7.5lb Flywheel
Thanks in advance for any advise, this is my first SERIOUS build and welcome any opinions.
AM I Missing ANYTHING?
Old Aug 2, 2005 | 09:29 AM
GUILOTINE's Avatar
Kill Gil
sounds good, just get a real good port (i.e. Portflow or alaniz)
Old Aug 2, 2005 | 10:12 AM
onepoint6i's Avatar
Default Re: (GUILOTINE)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by GUILOTINE &raquo;</TD></TR><TR><TD CLASS="quote">sounds good, just get a real good port (i.e. Portflow or alaniz) </TD></TR></TABLE>
post *****
Old Aug 3, 2005 | 03:16 AM
quickcarl's Avatar
Default Re: GSRLS-Vtec Build (crixzc)
If you are switching to main studs, be sure to have an experienced shop align hone the block after they're installed. It will change the main bore diameters and roundness with the studs vs. factory bolts. Do this when getting the block honed.
Old Aug 3, 2005 | 05:25 AM
Default Re: GSRLS-Vtec Build (quickcarl)
I read on the package that it said that but was unsure how the studs would change anything. Bling blaugh there goes more money
Old Aug 3, 2005 | 06:07 AM
Nick M's Avatar
I'd definitely invest in a shorter tranny.
B16/ITR at the least, maybe a jdm 4.7 final
Old Aug 3, 2005 | 06:19 AM
f@sth@tch89's Avatar
Default Re: GSRLS-Vtec Build (Evil Nick M)
i would recommend rc 310 injectors.....
Old Aug 3, 2005 | 09:17 AM
quickcarl's Avatar
It increases the clamping force on the main caps and that causes the bore to distort.
Old Aug 3, 2005 | 09:44 AM
onepoint6i's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by quickcarl &raquo;</TD></TR><TR><TD CLASS="quote"> I read on the package that it said that but was unsure how the studs would change anything.
It increases the clamping force on the main caps and that causes the bore to distort. </TD></TR></TABLE>
When the machine shop installs them,it may POSSIBLY distort the big end of the rod, to be safe and if it's a good machine shop, they're going to line hone it to spec for you...
dc2_poojan
15
Jul 8, 2011 08:59 AM
hatchn1.9
15
Dec 15, 2010 02:22 PM
TRQLESS
Apr 1, 2007 09:28 AM
crxsimike
Feb 14, 2006 12:07 AM
Novtecdohc
Sep 1, 2005 07:21 PM
