IN MIDDLE OF SWAP, NEED QUICK HELP
Old Aug 2, 2005 | 04:55 AM
1SIKEF8B20VTEC's Avatar
Default IN MIDDLE OF SWAP, NEED QUICK HELP
were swapping a B18A into my winter crx, the B18A came with a/c, the crx does not have a/c, we were wondering can we use the crank pulley from the crx, then use the alternator from the crx with the B18a motor, or can i use the crx alternator without switching pulleys, thanks guys
Old Aug 2, 2005 | 05:56 AM
JohnnieChimpo's Avatar
Default Re: IN MIDDLE OF SWAP, NEED QUICK HELP (northerntouch)
Just use the B crank pulley and remove the A/C.
I'm 95% sure that the D series Alt is not the same as the B series Alt.
Old Aug 2, 2005 | 06:01 AM
Default Re: IN MIDDLE OF SWAP, NEED QUICK HELP (JohnnieChimpo)
its not my question,im asking cause the b alternator is seized, i wanna know, can i use the d pulley on the b block, and use the d alternator, on the b-engine, k. thanks anyways
Old Aug 2, 2005 | 09:10 AM
Blaze45's Avatar
Brrraaaap!
Im using a d series alt. with a b series crankpully on my swap. I dont use one of the ribs on the crank pully tho. Seems to be working fine for about 4 years now.
Old Aug 2, 2005 | 10:25 AM
Default Re: IN MIDDLE OF SWAP, NEED QUICK HELP (Blaze45)
Thanks for the info but is there any reason i couldnt use the d-series pulley
Old Aug 2, 2005 | 10:30 AM
EP3_05's Avatar
If I am not mistaken you need a b series pulley because the crank snout size is different between the d and b series engines.
91civicEX's Avatar
try to get the b pulleys off first and then see if you still wanna use a d pulley
Old Aug 2, 2005 | 10:39 AM
can someone pls. answer my question, can i use my d-series crank pulley on the b-block, so i can use the d-series alternator, or can i just use the alternator, without switching pulleys, thanks again
Old Aug 2, 2005 | 11:20 AM
RA122324's Avatar
I say just buy the HASport A/C bracket and call it a day. hasport.com
Old Aug 2, 2005 | 12:00 PM
FR-MOB: ThE bEe GuY's Avatar
Default Re: (knwldge54)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by knwldge54 &raquo;</TD></TR><TR><TD CLASS="quote">I say just buy the HASport A/C bracket and call it a day. hasport.com</TD></TR></TABLE>
Damn does anyone ******* read?
HIS QUESTION: CAN HE USE THE CRANK PULLEY FROM THE D-SERIES ON HIS B-SERIES. OR, CAN HE USE THE ALTERNATOR FROM THE D-SERIES ON THE B-SERIES WITHOUT CHANGING THE CRANK PULLEY....****
And to answer his question, no you cannot use the D-Series crank pulley on the B-Series. I THINK you can take the B-Series Alternator pulley and put it on the D-Series alternator, but don't take my word on that because i'm not sure.
Old Aug 3, 2005 | 06:20 AM
Default Re: (ThE bEe GuY)
the post as nothing to do with a/c wake up sleepy
Old Aug 3, 2005 | 06:26 AM
mahatma's Avatar
Default Re: (northerntouch)
I don't see why the Bpulley and Dalternator wouldn't work. Misalignment would be your biggest problem (if that arises) otherwise you can always play with belt sizes til you find one that fits.
Amazing that nobody has tried this though......
Old Aug 3, 2005 | 07:28 AM
Speed PHreak's Avatar
Default Re: (mahatma)
1) NO ~~ you CANNOT use the d-series crank pulley on the B-series engine
2) YES ~~ you CAN use the d-series alternator on the B18A.
To use the d-series alternator you have to loosen the top braket to get the bolt to thread into the top alternator adjuster tab. Also you have to use a different alternator belt than either of the stock b-series or d-series engines come with. The B-series pulley is a 4 rib, while the d-series alternator is a 3-rib. Find the right length belt in a 3-rib and you should be set.
I've done that part "swap" many times and it works out just fine. Also with the d-series alternator you don't have to smash the inner frame rail to get the alternator to clear.
Old Aug 4, 2005 | 03:02 AM
Default Re: (Speed PHreak)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Speed PHreak &raquo;</TD></TR><TR><TD CLASS="quote">To use the d-series alternator you have to loosen the top braket to get the bolt to thread into the top alternator adjuster tab.</TD></TR></TABLE>
Do you have to leave the top bracket loose to get the D alt to fit? If so that sounds pretty ghetto.
Old Aug 4, 2005 | 11:18 AM
Blaze45's Avatar
Brrraaaap!
Default Re: (JohnnieChimpo)
I dont see what the big issue is here. I used the stock D series alt. and eathier the B series alt. bracket or the B series one. The D series one is working just fine, and there isnt really any ghettoness involved accpet that the crank pully on the B series motor is like 4 rib and the d series alt pully is 3. So you basically run with one rib showing but like I said Ive never had an issue.
Blaze
Old Aug 4, 2005 | 12:47 PM
Default Re: (Blaze45)
Wow dude, you should be a politician. You replied to my post without answering my question.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JohnnieChimpo &raquo;</TD></TR><TR><TD CLASS="quote">
Do you have to leave the top bracket loose to get the D alt to fit?</TD></TR></TABLE>
Old Aug 4, 2005 | 07:15 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JohnnieChimpo &raquo;</TD></TR><TR><TD CLASS="quote">Wow dude, you should be a politician. You replied to my post without answering my question.
No you don't leave it loose, that would be stupid. But sometimes it takes a bit of maneuvering to get everything lined up right. Thus the reason for have the top braket a tad loose in the beginning.
Timothy Yhtomit
Dec 2, 2018 11:02 AM
93 hatchguy
12
Feb 21, 2012 07:48 AM
eg2sol
Jan 27, 2008 12:03 PM
SiR Kid
Mar 12, 2004 01:38 AM
