msd 2 step pill?
Old Aug 2, 2005 | 03:30 AM
BoOsTiN Dc2's Avatar
Default msd 2 step pill?
Not sure if it belongs in this forum or not but... Do anyone know where i can buy single msd pills at or do i just have to buy a whole set?
Old Aug 2, 2005 | 08:22 AM
91civicDXdude's Avatar
i belive they are just sold by the set, but you might check ebay. Also, i have a chart on my website that lists the values of all the rpm pills, so you can take a simple resistor and make your own....
http://bhg.ath.cx/rpmpills.html
Old Aug 2, 2005 | 02:26 PM
turbo*s2k's Avatar
Default Re: msd 2 step pill? (tRaCeBuStAbUsTeR)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by tRaCeBuStAbUsTeR &raquo;</TD></TR><TR><TD CLASS="quote">Not sure if it belongs in this forum or not but... Do anyone know where i can buy single msd pills at or do i just have to buy a whole set?</TD></TR></TABLE>
Which one do you need? I have some...
As for buying them. You can't buy them individually. You have to buy a whole series like 6-6800 or 7-7800 etc...
Old Aug 2, 2005 | 02:52 PM
civicross's Avatar
Default Re: msd 2 step pill? (TurboChrgd_Civic)
I sell them.
Old Aug 3, 2005 | 12:07 AM
what u got franky? ill see if i can use it or not. something around 8,600 or 8,700. and im not sure which one i should use for the launch... how high u launch at and what size slicks? i got 24.5x7x13 but i think im gonna buy some 25x8.7x13 later on
Old Aug 3, 2005 | 09:50 AM
turbo*s2k's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by tRaCeBuStAbUsTeR &raquo;</TD></TR><TR><TD CLASS="quote">what u got franky? ill see if i can use it or not. something around 8,600 or 8,700. and im not sure which one i should use for the launch... how high u launch at and what size slicks? i got 24.5x7x13 but i think im gonna buy some 25x8.7x13 later on</TD></TR></TABLE>
I launch between 7400-7600 depending on where I'm at and how well the track is prepped. I'm running the 25" slicks. I use the same launch rpms on the 24" slicks. I run any where from 5-6psi again depending on traction and track prep. I pretty sure I have those pills. Let me know which one(s) you want and I'll check to see if I have them...
Old Aug 3, 2005 | 02:20 PM
i need a 8,600 or 8,700. for launch im not too sure which one i need but im assuming something around 7,000 or slightly higher. let me know what pill you have
Old Aug 3, 2005 | 07:07 PM
skunked's Avatar
you could always buy the adjustable control module. Pills can cost you more if you keep changing your setup......
Old Aug 4, 2005 | 02:08 AM
Default Re: msd 2 step pill? (skunked)
isnt that like $125-$150 for that?
Old Aug 4, 2005 | 07:31 AM
skunked's Avatar
http://www.msdignition.com/rpm_13.htm
They run about $54 plus shipping and tax.
http://store.summitracing.com/...h.asp
Two pill kits will cost more than this.....
Old Aug 4, 2005 | 08:06 AM
would something like this be better?
Old Aug 4, 2005 | 08:22 AM
turbo*s2k's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by tRaCeBuStAbUsTeR &raquo;</TD></TR><TR><TD CLASS="quote">would something like this be better?
http://store.summitracing.com/...h.asp</TD></TR></TABLE>
That would work too. You can use that for your 2 step/launching. Then you just need one pill for redline.
Old Aug 4, 2005 | 08:42 AM
skunked's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by TurboChrgd_Civic &raquo;</TD></TR><TR><TD CLASS="quote">
That would work too. You can use that for your 2 step/launching. Then you just need one pill for redline.</TD></TR></TABLE>
Right, I have a 2 step utilizing the adjustable rev control for my launch and a pill for my rev limit. It works well and gives me some flexibility with the different track conditions.
Old Aug 4, 2005 | 09:24 AM
turbo*s2k's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by skunked &raquo;</TD></TR><TR><TD CLASS="quote">
Right, I have a 2 step utilizing the adjustable rev control for my launch and a pill for my rev limit. It works well and gives me some flexibility with the different track conditions.</TD></TR></TABLE>
Or just buy an MSD digital 6. Has the 2 step feature that you can run off the clutch with a relay which is how I had it setup previously and worked great. "I have it setup a little different now."
With the digital 6 you can adjust redline and the 2 step to whatever you want.
yoffer
May 11, 2007 07:17 AM
omgwtfhaxnub
Feb 17, 2005 06:29 PM
Excelerate
May 20, 2004 02:40 PM
IdotheSHOCKER
Jun 9, 2002 06:21 PM
