OBD II b18b1..............obd I harness.........what dizzy?
Old Aug 1, 2005 | 10:52 PM
ben_eg6's Avatar
Default OBD II b18b1..............obd I harness.........what dizzy?
sup guys
I have just one question before doin the swap.
can I use obdI ls dizzy in an OBDII ls motor using OBDI harness? thanks
Old Aug 1, 2005 | 11:07 PM
Kendall's Avatar
Yes, you'll need an OBD-1 dizzy as the plugs are different.
Old Aug 1, 2005 | 11:24 PM
ben_eg6's Avatar
Default Re: (Kendall)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Kendall &raquo;</TD></TR><TR><TD CLASS="quote">Yes, you'll need an OBD-1 dizzy as the plugs are different.</TD></TR></TABLE>
will the timming be off, if I'm using obdI ecu, OBDI harness, and OBDI dizzy on an OBDII motor? Except the OBDII motor, everything else pretty much is OBDI including the chasis. thanks
Old Aug 2, 2005 | 07:00 AM
ben_eg6's Avatar
Default Re: OBD II b18b1..............obd I harness.........what dizzy? (Eg6B18C1)
patwitahonda
Oct 10, 2009 09:36 AM
wicked krx
Nov 5, 2008 11:31 AM
kris.is.awesome
Dec 30, 2007 10:39 AM
bvilleteggy62
Sep 20, 2007 06:09 PM
EJ8chu
Jan 28, 2006 08:16 PM
