fitting itr pistons into b16 block
Old Aug 1, 2005 | 09:33 PM
mrDFWmechanic's Avatar
Default fitting itr pistons into b16 block
i'm buiding a motor for a friend and we found a good deal on some barely used itr pistons and rod combo. i was told from one source that i would have to bore out the block of the B16 to make the itr pistons fit. then another said that all B seires pistons are 81mm except for a B20. i obviously am gonna hone the block thou and do more to it. and also i was told to use the stock b16 rods and just put the itr pistons on them. is any of this correct cause i dont know who to believe.
Old Aug 1, 2005 | 10:01 PM
anybody ?
Old Aug 1, 2005 | 10:24 PM
snowseeker's Avatar
Default Re: (iROCKtheSOHC)
ITR are the same bore as the B16. Rods will fit fine.
Old Aug 1, 2005 | 10:32 PM
SlowReaction's Avatar
Default Re: (snowseeker)
Pistons are the same. All you'll need is a good hone. Cant use itr pistons, there to long. ITR pistons and B16 pistons are almost the same compression it aint even worth the trouble. Pick up some ctr pistons.
turbo_hatch93
May 21, 2006 11:02 PM
crxowner
Jul 26, 2005 05:57 PM
civic-si-2000
Jun 2, 2005 07:57 AM
palmeref9
Jan 28, 2004 08:25 PM
robhamaliuk
Jan 24, 2003 10:17 AM
