>>>>FS: 95 GSR Rear Disc Brakes w/ Brand new rotors and AEM pads<<<<
i assume, but want to confirm, does it come with the entire trailing arm assembly, hub, e-brake lines etc.?
ready to bolt on and go?
my car has ABS, i assume it makes a difference if your set up doesn't have ABS?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Type V »</TD></TR><TR><TD CLASS="quote">i assume, but want to confirm, does it come with the entire trailing arm assembly, hub, e-brake lines etc.?
my car has ABS, i assume it makes a difference if your set up doesn't have ABS?</TD></TR></TABLE>
yes, its the complete conversion. it came out of a gsr so its ABS.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by cycocivic »</TD></TR><TR><TD CLASS="quote">where are you located?</TD></TR></TABLE>
located in the bay area
