clutch stalls out in 1st gear why???
Old Aug 1, 2005 | 05:50 PM
hatchinprogress's Avatar
Default clutch stalls out in 1st gear why???
i have a 92 ls teg (w/abs) well all of a sudden (today) when i drive the car in 1st gear it start to shake(like it wants to stall) and has stalled a few times. what could be wrong???
Old Aug 1, 2005 | 06:12 PM
nickG's Avatar
Default Re: clutch stalls out in 1st gear why??? (hatchinprogress)
maybe you suck at driving???
does it happen all the time, even if you slip the clutch a bunch at high rpms???
Old Aug 1, 2005 | 06:31 PM
Default Re: clutch stalls out in 1st gear why??? (nickG)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by nickG &raquo;</TD></TR><TR><TD CLASS="quote">maybe you suck at driving???
does it happen all the time, even if you slip the clutch a bunch at high rpms???</TD></TR></TABLE> haha funny, but no it just started today(i even thought i might of stalled at 1st but it keeps hapinin) the car kinda shakes and then stalls
Old Aug 2, 2005 | 01:38 PM
bump for answer
Old Aug 2, 2005 | 03:38 PM
rkrone's Avatar
what mods have you done?
does this happen in other gears?
how old is the clutch?
check all stupid things - oil, gas, coolant, plugs, all vaccum lines and electrical connections tight?
sorry for vauge answer to vauge question
Old Aug 2, 2005 | 05:37 PM
Default Re: clutch stalls out in 1st gear why??? (rkrone)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by rkrone &raquo;</TD></TR><TR><TD CLASS="quote">what mods have you done?
</TD></TR></TABLE>the engine is stock (ls), but the guy i bought the car from says there is a gsr flywheel in there(he had a gsr in the car before i bought it) and it's only happened in 1st (and no it aint my driving).... changed the oil last week, coolant is good,full tank off gas(and it still happens) and the vac lines look good and i dont notice any thing wrong with the electrical <TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by rkrone &raquo;</TD></TR><TR><TD CLASS="quote">sorry for vauge answer </TD></TR></TABLE> no problem, thanks for tryin to help me
Old Aug 2, 2005 | 05:53 PM
reactiondc2's Avatar
if it onlt does it when you are taking off from a stop then it sounds like your clutch is worn out and is "chattering" otherwise i dunno
Old Aug 2, 2005 | 10:58 PM
phateless's Avatar
it sounds like he's bogging more than chattering. when was the last time it had a tune-up? try that, run some fuel cleaner, take it out on freeway and rail on it a bit.
Old Aug 3, 2005 | 12:41 PM
Default Re: clutch stalls out in 1st gear why??? (reactiondc2)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by reactiondc2 &raquo;</TD></TR><TR><TD CLASS="quote">if it onlt does it when you are taking off from a stop then it sounds like your clutch is worn out and is "chattering" otherwise i dunno
</TD></TR></TABLE> im starting to think this might be the prob.<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by phateless &raquo;</TD></TR><TR><TD CLASS="quote">it sounds like he's bogging more than chattering. when was the last time it had a tune-up? try that, run some fuel cleaner, take it out on freeway and rail on it a bit.</TD></TR></TABLE>thanks for the reply, ill give it a try (but i think it's more of a clutch problem )
Old Aug 3, 2005 | 03:59 PM
Irish Integra's Avatar
Sounds like the clutch is on its way out to be honest, it would bog in all gears if it was bogging. Once the car is moving, it's not so hard on the clutch, the most amount of torque is required taking off.
You may have a problem ordering a new clutch off the VIN because of that GSR flywheel. There's prob a GSR clutch and pressure plate on there too. Be prepared for a day os two off the road!
In any case fit a clutch kit, no point in only fitting a disc because if the pressure plate or bearing go later on, its twice the work.
Old Aug 3, 2005 | 08:06 PM
NKSforever's Avatar
Steve.. Email me S240161@yahoo.com, or hit me up on AIM Globe161
Old Aug 5, 2005 | 10:00 AM
Default Re: (NKSforever)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by NKSforever &raquo;</TD></TR><TR><TD CLASS="quote">Steve.. Email me S240161@yahoo.com, or hit me up on AIM Globe161</TD></TR></TABLE> who are you? and how do you know my name?
Old Aug 5, 2005 | 04:34 PM
nickG's Avatar
Default Re: (hatchinprogress)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by hatchinprogress &raquo;</TD></TR><TR><TD CLASS="quote"> who are you? and how do you know my name?</TD></TR></TABLE>
oh noooooss......an e-stalker
Old Aug 5, 2005 | 05:29 PM
Default Re: (nickG)
oh noooooss......an e-stalker</TD></TR></TABLE> thats what im thinkin ((as i run to go lock all my e-windows and e-doors )
Old Aug 5, 2005 | 05:50 PM
projectTeG's Avatar
have you tried to adjust your clutch cable? could be worth a shot.maybe you need to back off the screww to get a lil more throw in the clutch.
Old Aug 5, 2005 | 05:52 PM
Default Re: (projectTeG)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by projectTeG &raquo;</TD></TR><TR><TD CLASS="quote">have you tried to adjust your clutch cable? could be worth a shot.maybe you need to back off the screww to get a lil more throw in the clutch.</TD></TR></TABLE> na the car is a '92 so it's hydro
Old Aug 5, 2005 | 06:08 PM
projectTeG's Avatar
um unless it was converted 90-93 tegs are cable they went hydro in 94
Old Aug 5, 2005 | 06:26 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by projectTeG &raquo;</TD></TR><TR><TD CLASS="quote">um unless it was converted 90-93 tegs are cable they went hydro in 94</TD></TR></TABLE> um i think that 92 and up is obd-1 and i know there isnt a cable
Old Aug 5, 2005 | 06:37 PM
GolfIVTyBiggums's Avatar
eh, i have a 92 teg.. an ls at that.. and it is MOST certainly beyond any doubt, cable, was from the factory, and it is now. I replaced the transmission with a b16 CABLE transmission, as this is the only transmission our cars will use. If your car was somehow, by some voodoo trickery converted the hydro tranny, that voodoo trickery is probably causing your problems. Mrs. Cleo probably has a fix for you... Although she may be in jail.
Old Aug 5, 2005 | 08:51 PM
Default Re: (GolfIVTyBiggums)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by GolfIVTyBiggums &raquo;</TD></TR><TR><TD CLASS="quote">eh, i have a 92 teg.. an ls at that.. and it is MOST certainly beyond any doubt, cable, was from the factory, and it is now. I replaced the transmission with a b16 CABLE transmission, as this is the only transmission our cars will use. If your car was somehow, by some voodoo trickery converted the hydro tranny, that voodoo trickery is probably causing your problems. Mrs. Cleo probably has a fix for you... Although she may be in jail<U></U>.</TD></TR></TABLE> well i better tripple check and im in good with mrs. cleo's sister so ill give her a call and see if they put some voodoo juice in my car
Old Aug 5, 2005 | 09:22 PM
PatrickGSR94's Avatar
Community Builder
Community Influencer
Active Streak: 60 Days
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by hatchinprogress &raquo;</TD></TR><TR><TD CLASS="quote"> na the car is a '92 so it's hydro</TD></TR></TABLE>
90-93 Integras had clutch cables, with no clutch master cylinder. I'm willing to bet there is no reservoir sitting next to the brake master cylinder, like there is on 94+ Integras.
If there is, then I definitely want to see pics of that.
Old Aug 5, 2005 | 09:43 PM
projectTeG's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by hatchinprogress &raquo;</TD></TR><TR><TD CLASS="quote"> um i think that 92 and up is obd-1 and i know there isnt a cable</TD></TR></TABLE>
um no, 90-91 obd0 tegs had the cable and 92-93 tegs had the cable honda converted the integra to hydro when the went to the dc chassis. the the civics switch to hrdro in 92 the preludes in 92 and the accords i beleive in 90....lol, had to run down the line
yeegsr
14
May 17, 2007 05:25 AM
Komptech
Mar 29, 2005 07:35 PM
-BlueGSR-
May 1, 2003 09:27 AM
civicheaven151
17
Jul 6, 2002 07:25 PM
