4th gen differences between h23 and h22? help?
Hey guys what is the differences between these 2 car models beside the obvious like the engine/ecu/tranny and the p13 ecu? I was wondering if all the wiring is the same and is the electrical the same? I mean I was told that a 93 prelude si has a mechanical speedo vs electrical on the h22a vtec model? Should they all be the same besides the engine/ecu/tranny and p13 ecu? thanks let me knw
Btw, I'm waiting to swap my h23a into a 93 4th gen prelude vtec model. Yeah yeah I know but my prelude si was wrecked in a crash but the motor is still good and I tracked down a 93 vtec shell for it.
Everything is the same. 93+ Si's had the same wire harness as the VTEC model too. For 92's, all you have to do is run the wires to the VTEC solenoid and pressure switch.
The only difference I can think of would be the wiring for the VTEC 6x9 "subwoofer"
thanks man
that's all I needed to know. I guess I was being bullshitted today about the 93 si being mechanical and the 93 vtec being electrical speedo.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by import_driver »</TD></TR><TR><TD CLASS="quote">thanks man
that's all I needed to know. I guess I was being bullshitted today about the 93 si being mechanical and the 93 vtec being electrical speedo.</TD></TR></TABLE>
94 started the electrical speedo
that's all I needed to know. I guess I was being bullshitted today about the 93 si being mechanical and the 93 vtec being electrical speedo.</TD></TR></TABLE>94 started the electrical speedo
thanks for all the replies
Yeah I just checked up the vin # and both of them says 93 prelude. So I shouldn't run into any problem correct? Is the dash harness the same on the 93 prelude si and the 93 prelude vtec? Because the shell that I bought has a burn harness but the 93 si has an unburnt harness and is it Plug and Play?
MikeLuder
May 8, 2003 12:15 PM
