Help!! clutch!!
Old Feb 19, 2002 | 09:26 PM
R-1303's Avatar
Default Help!! clutch!!
first i did a search and not enough info.....
I installed a clutch net stage 2 from importparts.com and when i start in first i could hear the clutch spinning not engaging..also it makes a weird squeking noise..and the clutch pedal is softer than stock..what could this be?!?!? plz help
thank you..ITR-1303
Old Feb 20, 2002 | 08:23 AM
dho311's Avatar
Default Re: Help!! clutch!! (R-1303)
Did you put the new throwout bearing in it and did you put the anti seize lubricant on the spindal. OH yeah and did you resurface the flywheel. And see if you need to bleed the clutch line it hydrolic. If all that was done. I would pull it back out and take a look.
Old Feb 20, 2002 | 09:39 AM
SiR Kid's Avatar
New User
Sounds like how mine was at first... Clutch Issues Thread
We adjusted it some and the pedal was VERY light... and at the VERY top started to grab...
If you rev the car once it's broken in, it doesn't feel like the pedal will come back up off the floor does it?
Sounds JUST like my situation.
My PP ended up being the culprit.. it ended up breaking after 700 miles.
[Modified by SiR Kid, 12:46 PM 2/20/2002]
Old Feb 20, 2002 | 09:50 AM
R-1303's Avatar
Default Re: Help!! clutch!! (SiR Kid)
i think we have the same problem...are u using clutch net???
Old Feb 20, 2002 | 09:56 AM
SiR Kid's Avatar
New User
Read the thread... Mine car's apart now
Old Feb 20, 2002 | 10:02 AM
R-1303's Avatar
e mail me with ur phone # so we can talk!!! i'll give u mine!....neva mind..u got mail!!!
[Modified by R-1303, 7:07 PM 2/20/2002]
Old Feb 20, 2002 | 10:04 AM
SiR Kid's Avatar
New User
You've got mail.
Old Feb 20, 2002 | 10:07 AM
R-1303's Avatar
ahahh i know now u do!!! call me up
[Modified by R-1303, 7:08 PM 2/20/2002]
jdmcivicracer89
21
Jun 5, 2008 09:39 AM
neopheus
Mar 13, 2005 10:20 PM
vteec
Oct 28, 2003 02:21 PM
R-1303
Feb 20, 2002 12:05 AM
