real stock HP
i'm a noobie to the automotive customization scene, so forgive me for my lack of knowledge on the subject. i just came into possession of a 95' Accord EX with the F22A2 VTEC. i was trying to see how much HP the thing has stock, but all i keep getting is this "F22A2 2.2 SOHC VTEC PGM-FI 2156 108 kW ?? '94-'97 Accord EX". how much hp does it have? if any of you guys know, it would be greatly appreciated.
-Chris
-Chris
well you might try searching for the f22b1 since that's the motor that supposed to come in the 94-97 accord ex's...anyways, your motor is rated from the factory as having 145 hp and 147 lb/ft of tourque...
thanks dudes. yeah, that helps a bunch. i just want to tally up the total hp, cause i intend on buying a CAI(not decided on brand, yet) and some sort of exhaust, probably catback of sorts. i just wanted an accurate sum of horses to brag to my friends aboot.
-thanks again,
-Chris
-thanks again,
-Chris
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by newaccordowner »</TD></TR><TR><TD CLASS="quote">i just wanted an accurate sum of horses to brag to my friends aboot.</TD></TR></TABLE>
then get it dynoed...your wheel horsepower is the accurate power...most times, stock accords dyno at around 115-120 whp...not to mention, the gains you get from your intake, exhaust, header etc are never the same as they are advertised...
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by newaccordowner »</TD></TR><TR><TD CLASS="quote">thanks dudes. yeah, that helps a bunch. i just want to tally up the total hp, cause i intend on buying a CAI(not decided on brand, yet) and some sort of exhaust, probably catback of sorts. i just wanted an accurate sum of horses to brag to my friends aboot.
-thanks again,
-Chris</TD></TR></TABLE>
b4 you go and dump a bunch of money into bolt ons I/H/E (intake,header,exhaust) do a search on how much they add. Nick H is right..you wont get what the manf. says you will. bolt ons dont do a whole lot for our cars unless your gonna turbo it or use nitrous.
I/H/E will add a few hp, but not enough to brag about. figured i'd give ya a heads up on that.
just do a search and you'll see what i'm talkin bout.
-thanks again,
