B17A1 head on B18C1 block. Pros and cons?
Ok so the other night I accendentally threw a money shift and I bent some valves in my B18C1 on cylinder 3. I have this B17A1 long block sitting in my garage and the head is all assembled except the cams have been removed. I know the B17 head is basically a B16 head so I'm curious how my performance, compression ratio will be altered. Will the compression be higher or lower? Will the engine be more responsive or less? I guess its basically a poor man's type r minus the pistons/ & mild PP.
Also my friend told me something about using the B16 exhaust cam and the GSR intake cam or visa versa.
Any help is appreciated.
-Chris
-Chris
Your compression will drop by .2 so performance would be slightly reduced... If you use a 2 layer headgasket, that should keep your compression the way it was. I'm not sure about the rest.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 00Red_SiR »</TD></TR><TR><TD CLASS="quote">Your compression will drop by .2 so performance would be slightly reduced... If you use a 2 layer headgasket, that should keep your compression the way it was. I'm not sure about the rest.</TD></TR></TABLE>
Isn't the B16 combustion chamber a little smaller though?
Thanks for the numbers
. What about the cam issue. Do you have any idea what kind of setup I should use. Should I mis match the GSR/B16 cams?
Bump for All Motor goodness. Is there anything positive from doing this? At least I won't have the *** of an IM like on the GSR anymore. Anyway I'm starting project swap out fucked up head in a couple hours when its not so hot.
So the B17 cams are the same as b18c cams?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by UNKNOWN_MEMBER »</TD></TR><TR><TD CLASS="quote">while looking for the thread that said the b17 has gsr cams, i found other threads saying the b17 cams are closer to being 92+ b16 cams. </TD></TR></TABLE>
That is true
, They are their own specs but but still closer to 92+ B16 cams
That is true
SirRevvs
13
Aug 3, 2005 09:14 AM
