will this pass smog? EGR headache
Old Aug 1, 2005 | 03:32 PM
stockegsix's Avatar
Default will this pass smog? EGR headache
Fixed, I used a PM6 ecu
Modified by stockdc2 at 11:20 PM 8/3/2005
Old Aug 1, 2005 | 03:34 PM
91civicEX's Avatar
Default Re: will this pass smog? EGR headache (stockdc2)
if ur throwing a code most smog places wont even try to smog ur car. u could try to unhook the CEL completely since most will not look at ur ecu. or y not use a hf ecu? it will probably burn cleaner?
Old Aug 1, 2005 | 04:23 PM
stockegsix's Avatar
Default Re: will this pass smog? EGR headache (91civicEX)
i have a Hf ecu right now, and it looks for an egr. the Si ecu doesnt look for it.
Old Aug 1, 2005 | 08:39 PM
stockegsix's Avatar
anyone?
Old Aug 1, 2005 | 08:42 PM
silentdork818's Avatar
The si ecu will run richer for sure, so...might make things worse.
Old Aug 1, 2005 | 08:53 PM
stockegsix's Avatar
Default Re: will this pass smog? EGR headache (ef four door)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ef four door &raquo;</TD></TR><TR><TD CLASS="quote">The si ecu will run richer for sure, so...might make things worse.</TD></TR></TABLE>
hmmm... but this will for sure eliminate code 12 right. I just need this car to pass smog so I can drop in the motor
Old Aug 2, 2005 | 12:57 AM
ALLMOTORCRX20's Avatar
When you smog your car and the smog station see's an EGR, they have to check and make sure it works so if there is something wrong with your EGR, then you wont pass smog even if you get good reading from the smog machine.
Old Aug 2, 2005 | 06:05 AM
stockegsix's Avatar
Default Re: will this pass smog? EGR headache (ALLMOTORCRX20)
thanks... I will give it a shot man, or how can I fix this EGR problem. can I just get a new sensor, clean it or what should I do?
Old Aug 2, 2005 | 07:03 AM
oakpwr's Avatar
hit up dirty, ghetto smog shops and tell them you will pay them to pass you. since its a bribe they will know you aint a official and will be more likely to help you out. its a bitch cuz if they get caught then i heard they take all their smog equip away and get massive fines, hence why most places are so stringent on smog tests.
good luck bro, its going to probably run you at least 100$ from what i heard
Old Aug 2, 2005 | 07:52 AM
temp's Avatar
Default Re: will this pass smog? EGR headache (oakpwr)
diu just get a new EGR valve from autozone, they are like $60, use it then return it. using an SI ecu WILL make you fail. for half assing things
Old Aug 2, 2005 | 04:28 PM
stockegsix's Avatar
Default Re: will this pass smog? EGR headache (temp)
I did go to autozone, they dont have EGR valve for the CRX, BTW, the PM6 ecu from the SI got rid of the CEL.
Old Aug 2, 2005 | 04:35 PM
ironchef25's Avatar
do you guys know any shop. i need to pass my crx b16 testpipe. i have 150 know anyshop. asap cause my reg is due soon.
sorry to jack but im desperate here.
Old Aug 2, 2005 | 07:55 PM
Default Re: will this pass smog? EGR headache (ironchef25)
Man u foos gotta keep it on the down low...never know when THE MAN might be watching...
Old Aug 2, 2005 | 11:36 PM
SmogTech01's Avatar
PM me i got a hook up
Modified by SmogTech01 at 12:47 AM 8/3/2005
Old Aug 3, 2005 | 07:27 AM
temp's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by stockdc2 &raquo;</TD></TR><TR><TD CLASS="quote">I did go to autozone, they dont have EGR valve for the CRX, BTW, the PM6 ecu from the SI got rid of the CEL.</TD></TR></TABLE>
i bought one there just fine for an HF.......and just because it got rid of the CEL doesnt mean it will pass tailpipe
Old Aug 3, 2005 | 02:11 PM
stockegsix's Avatar
thanks man, Im gonna give it a shot
hondatech2000
Oct 13, 2011 08:40 PM
SuperDuude
Oct 26, 2004 11:26 PM
wid326
26
Aug 19, 2004 07:21 PM
Drow
Apr 11, 2003 06:12 PM
