Need help!! Pistons & rings
Old Aug 1, 2005 | 02:58 PM
Hoffy's Avatar
Default Need help!! Pistons & rings
My rings went out in my B18C1. I have decided to buy a new set of pistons while I have it torn apart. My problem is I'm not sure what I should get for pistons. I am planning on keeping it N/A and do not want too high of comp. ratio. Would like to have a little extra hp for my daily driver. I do have a fully built head (P&P as well), Skunk2 IM, & 70mm TB.
Thanks for any advise!!
Old Aug 1, 2005 | 05:38 PM
RedEj8's Avatar
Default Re: Need help!! Pistons & rings (Hoffy)
itr pistons.
Old Aug 1, 2005 | 06:44 PM
hybrid_vtec's Avatar
Default Re: Need help!! Pistons & rings (reddohcvtec)
Or P30's
Old Aug 1, 2005 | 08:36 PM
EK Josh's Avatar
Default Re: Need help!! Pistons & rings (hybrid_vtec)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by hybrid_vtec &raquo;</TD></TR><TR><TD CLASS="quote">Or P30's</TD></TR></TABLE>
Bingo
...They're just a little hard to come by.
Old Aug 1, 2005 | 08:56 PM
jrthecow311's Avatar
hey the samething happend to me, my advice would to be to upgrade. i would do wiseco heatcoated 12.0.1 compression pistons. just make sure you have plenty of fuel, like 310cc injectors and fuel pump. then later on down the road you can do a stage 2 cam, you would easly put down 200hp at the wheel-daily driver. just reasearch.
Old Aug 2, 2005 | 04:44 PM
Hoffy's Avatar
Default Re: (jrthecow311)
Cool! I already have a fuel pump and bigger injectors (440's - probably too big?) I'm looking at some pistons now with 11.5.1 comp ratio.
I was already close to 200whp (193) with the stage 1 cams I had. Yes, I am planning on getting stage 2 cams, probably Skunk2's.
Thanks!!!!
Ryan#1
Oct 2, 2008 06:27 PM
94civicgsr
Feb 4, 2008 09:27 PM
WalkerGSR1
Sep 4, 2006 10:53 AM
h22_crx
May 4, 2006 04:57 AM
Mr. Vapor
Aug 28, 2005 09:06 PM
