What Else Can I Do
Old Aug 1, 2005 | 01:49 PM
D15BHatchbackcivic's Avatar
Default What Else Can I Do
I have a D15b V-Tech in my Hatchback. I was wondering what else could i do to it for HP, I already have Cold Air, Headers and Exhaust. I want more POWER. Also how Much HP does my D15B have Stock.
Thanks
Old Aug 1, 2005 | 02:12 PM
FalkenSiR's Avatar
Default Re: What Else Can I Do (D15BHatchbackcivic)
Go all motor or FI. And search too.
Old Aug 1, 2005 | 02:24 PM
MikeD718's Avatar
Default Re: What Else Can I Do (fast88std)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by D15BHatchbackcivic &raquo;</TD></TR><TR><TD CLASS="quote">I have a D15b V-Tech in my Hatchback.</TD></TR></TABLE>
you could start by spelling VTEC correctly. that should give you about 5 extra HP.
Old Aug 1, 2005 | 02:36 PM
ek9800's Avatar
Default Re: What Else Can I Do (MikeD718)
You should convert from V-tech, to Vtec. Then after that, you should go turbo. Only way you're going to get power out of a D-series.
Old Aug 1, 2005 | 02:40 PM
h kid's Avatar
forget the all motor your never gonna have enuff ***** as fi and your gona spend a ton of money and then blow up, go fi and that way if you blow the engine you can get another one for like 300.00 and put all the turbo stuff back on, you dont even have to build up your internals as long as you dont over boost. check out http://www.homemadeturbo.com
Deemeetree's Avatar
Electrician
All of you need to stop with the vtech, vtak, etc. bandwagon.
Original poster, you need to search.
crxrider07
Aug 30, 2008 09:18 PM
robs93civic
Apr 17, 2006 03:56 PM
JDM915
11
May 19, 2005 05:32 PM
igo4bmx
Jan 8, 2005 09:32 PM
postinINsfc
Aug 11, 2003 03:33 PM
