d15 non vtec
Old Apr 14, 2006 | 02:12 PM
robs93civic's Avatar
Default d15 non vtec
i have a d15 non vtec in my 93 civic and i was wondering what all i would really need to do before i started boosting?
Old Apr 14, 2006 | 02:13 PM
MasterShake's Avatar
a turbo
________
MARYJANE
Old Apr 14, 2006 | 02:16 PM
Default Re: (BLAZE_13)
lol i know that... i mean as far as replacing anything in the motor and stuff to make it capable of holding the turbo and the power increase
Old Apr 14, 2006 | 02:24 PM
how much boost?
________
Lovely Wendie
Old Apr 14, 2006 | 02:27 PM
atleast 12lbs... but if i could get more than i want to try for more
Old Apr 14, 2006 | 02:33 PM
E46Kid's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by BLAZE_13 &raquo;</TD></TR><TR><TD CLASS="quote">a turbo</TD></TR></TABLE>
Old Apr 14, 2006 | 03:04 PM
Default Re: (EkSi)
so wat all would i have to do to be able to boost atleast 12lbs
Old Apr 14, 2006 | 03:17 PM
schardbody's Avatar
nobody can answer that. i mean you could throw 12psi at it and not even tune it and it will drive. how long it stays together is up to you. your budget, knowledge, etc.... either way, if you have to ask such a broad question you arent no were near ready for a boosted ride. it takes more than parts to make a boosted car last. in the mean time check out http://www.homemadeturbo.com its a site mainly populated with honda owners.
Old Apr 14, 2006 | 03:50 PM
Default Re: (schardbody)
alright thanks.. i was asking because i didnt know if my motor would be able to handle it.. and i meant as far as replacing the internals and stuff.. and if i would boosting 12lbs right now i would pretty much blow the head but thanks for the info
Old Apr 14, 2006 | 05:53 PM
Quick Shot xMLx's Avatar
Default Re: (robs93civic)
A d15 is not going to handle 12 pounds without reworking the internals. Depending on your miliage I would aim more at 8 pounds.
Old Apr 14, 2006 | 06:56 PM
nonvtecD's Avatar
psi means nothing, 12 psi on a T3 is not the same as 12 psi on a T4. The question is how much hp are you looking for? D15's bend rods when you go much past 200 hp. You need to do a lot of research before you go near a turbo kit.
Old Apr 14, 2006 | 07:53 PM
Default Re: (nonvtecD)
after i redo my internals it will still not be able to hold that much? i figured after i redo my internals it shouldnt be a problem but i was asking just be be sure so it isnt a real good idea?
Old Apr 14, 2006 | 08:01 PM
nonvtecD's Avatar
you're going to put rods and pistons in your D15? considering the only rods for 1.5's are real expensive I think you dont know what you're talking about.
Old Apr 14, 2006 | 08:03 PM
so your sayin its impossible to get them then?
Old Apr 14, 2006 | 08:09 PM
and couldnt i get the pistons from a d16 or something since its a D series motor or get some kind better pistons that fit a d16 and put them in mine?
Old Apr 15, 2006 | 05:09 PM
nonvtecD's Avatar
Yes, pistons are easy, but I'm telling you buying rods for a D15 is not worth it. IMO building a D in the first place isn't really worth it, just boost the stock motor and do it right, you'll love it.
Old Apr 15, 2006 | 06:57 PM
LSVTECKID's Avatar
i'd rather boost a z6 .. just me though
or you could just use that money on a swap ^_^
Old Apr 15, 2006 | 07:34 PM
FalkenSiR's Avatar
Default Re: (LSVTECKID)
Z6 for boost FTW. D15 will take some extra money just to make it handle 10 psi (average turbo) reliably.
Old Apr 15, 2006 | 07:39 PM
Default Re: (fast88std)
so its not really worth building up the d15?
Old Apr 15, 2006 | 07:49 PM
nonvtecD's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by fast88std &raquo;</TD></TR><TR><TD CLASS="quote">Z6 for boost FTW. D15 will take some extra money just to make it handle 10 psi (average turbo) reliably.</TD></TR></TABLE>
not true, boost your D15, mine ran for 6 months at 10 psi with no problems and I pulled it long before it blew up. Boost your D15 and do it right.
Old Apr 15, 2006 | 08:10 PM
schardbody's Avatar
you must suck at life if you ran a 14.8 on 10psi.
Old Apr 15, 2006 | 08:28 PM
Syndacate's Avatar
lool, I was gonna say "swap", but the first post was "turbo" instead ;-P
Old Apr 15, 2006 | 09:08 PM
vlc92189's Avatar
Default Re: (Syndacate)
yeah im with him.. unless your really in this whole boosting your d15 non vtec.. buy an ls.. if your low on cash.. then boost it months down the road.. turn out alot better
Old Apr 15, 2006 | 09:36 PM
schardbody's Avatar
i would like to know where everyone comes off thinking an LS swap is soooo cheap. i mean, hmotors wants $2200+shipping. and thats the cheapest i have found. i have been looking for months for a wrecked teg to use for swap and cant even find one of those near me. junkyard, forget that, $900 for an LS longblock. JDM B18b longblock $800, tranny $400, harness $75-100, axles $150, linkage $125, ecu $100. it adds up.
Old Apr 16, 2006 | 07:31 AM
Syndacate's Avatar
sounds like if you piece it together it's cheaper than if u were to buy it from hmotorsonline..?
