fuse directions for 97 EX civic
does anyone have the chart where all the fuses plug into what accesory, ex. radio, ac, etc? which fuse goes to what, my cover where the fuse chart was was stolen. thank you.
do you have an owner's manual? should be in there. also there is a fuse box under the hood next to the battery.
Thank you, also i have another problem, my radio (sony cdx) keeps turning on and off, and now it's completely off, i thought it was the fuse but that wasn't the problem, have you had any problems like that? if so how did you cure it?
that sounds like a loose wire, did you install it? how old is the stereo and when it turns itself off can you turn it right back on? Also... say you turn the car off but the radio was on but when you turn the car on again and the deck is turned off, is that what you mean? There is a wire that comes to mind that needs to have constant 12v power and it saves the memory for the radio, do you loose all stations and settings?
i did not install it, a radio shop did, and also it is always off when i turn off the car and i turn it on when i listen to it, it was never loud it just finally went out...strange.
Trey Boston
Audio / Security / Video
Mar 27, 2019 10:38 AM
Stover954rr
Jul 31, 2012 03:09 PM
kev92ex4door
Jul 21, 2008 08:25 AM
