where to mount the sensor(for water temp gauge on a d16z6)
Old Aug 1, 2005 | 12:47 PM
hatchinprogress's Avatar
Default where to mount the sensor(for water temp gauge on a d16z6)
can someone show some pics of where to install the sending unit(from a autometer water temp gauge) on a d16z6????? (the reason i ask id because on my friends gsr, there is a "plug" that removes from the block and the sending unit screws right in)
Old Aug 1, 2005 | 12:56 PM
MugenHonda's Avatar
From: With my POS D15B2, Whereever whenever, United States
Default Re: where to mount the sensor(for water temp gauge on a d16z6) (hatchinprogress)
well both temp sensors are on the left side of the block.
Old Aug 1, 2005 | 05:48 PM
Default Re: where to mount the sensor(for water temp gauge on a d16z6) (MugenHonda)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by MugenHonda &raquo;</TD></TR><TR><TD CLASS="quote">well both temp sensors are on the left side of the block.
</TD></TR></TABLE> well can i keep both sensors and use my autometer gauge? and can someone post pics??
Old Aug 1, 2005 | 06:32 PM
anybody got a water gauge in there car?
Old Aug 1, 2005 | 07:41 PM
dnoredsi's Avatar
get an ac auto technique hose adapter. you just have to cut the radiator hose , clamp this piece in between and screw the sensor into it.
Old Aug 2, 2005 | 12:46 AM
Scrapin4DR's Avatar
Default Re: where to mount the sensor(for water temp gauge on a d16z6) (dnoredsi)
i tried installing one of them autozone temp gauges and the lil parts that u plug ur sending unit into and then plug that into ur block , none of them would fit the opening on my block do i have to get one especially for civic or did i plug it in the wrong place i tried plugging it in under the dizzy , i was told that's the right plug and the lil plugs that come with the gauge don't fit , so like i said do i just need to get me one for civic or wat?? my temp gauge isn't working for year and a half now , so if anyone knows which gauge i need can u tell me
Old Aug 2, 2005 | 01:37 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by dnoredsi &raquo;</TD></TR><TR><TD CLASS="quote">get an ac auto technique hose adapter. you just have to cut the radiator hose , clamp this piece in between and screw the sensor into it.</TD></TR></TABLE> well im tryin to avoid tappin into my rad. hose<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Scrapin4DR &raquo;</TD></TR><TR><TD CLASS="quote"> i tried plugging it in under the dizzy </TD></TR></TABLE> yeah i thought there is an area on the block that the sensor screws into.....anyone have pics of there water temp gauge(where it taps into engine??)???
Old Aug 2, 2005 | 01:49 PM
built562's Avatar
that will only work if the gauge he is trying to install is mechanical.
so is your gauge mechanical or electrical?
from my experience mechanical is better. more accurate i mean, harder to install but more acurate. and i do suggest coupling into the top radiator hose, you can make it look clean if you do it right.
electrical sending units absord heat from the block and head and translate that into in-accurate water temps.
i hope this gives you some help
Old Aug 2, 2005 | 05:39 PM
Default Re: where to mount the sensor(for water temp gauge on a d16z6) (built562)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by built562 &raquo;</TD></TR><TR><TD CLASS="quote">
</TD></TR></TABLE> it's mechanical......is there anyway to install it (without tappind into the rad hose and still keep the stock water gauge also??)????
Old Aug 2, 2005 | 10:48 PM
built562's Avatar
since its mechanical you will need to find a place to "tap" into a water source. thats why people use the radiator hose cuz its easy to work on and the sensor will give you an accurate reading with out absorbing heat from the block/head.
you can also take off the water outlet (the thing that holds the thermostat) and tap your own hole
Old Aug 3, 2005 | 12:44 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by built562 &raquo;</TD></TR><TR><TD CLASS="quote">since its mechanical you will need to find a place to "tap" into a water source.</TD></TR></TABLE> does anyone know if there is a spot on the motor that the sender will screw into???? (like i said my friend's gsr has a plug that unscrewed for the sender and this is a stock thing(he didnt make it or tap a hole))??
Old Aug 3, 2005 | 06:11 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by hatchinprogress &raquo;</TD></TR><TR><TD CLASS="quote"> does anyone know if there is a spot on the motor that the sender will screw into???? (like i said my friend's gsr has a plug that unscrewed for the sender and this is a stock thing(he didnt make it or tap a hole))??</TD></TR></TABLE>
Old Aug 5, 2005 | 10:01 AM
bump
Old Aug 5, 2005 | 05:31 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by hatchinprogress &raquo;</TD></TR><TR><TD CLASS="quote">bump</TD></TR></TABLE>
Old Aug 5, 2005 | 06:27 PM
ta tha tizop
Old Aug 5, 2005 | 06:30 PM
Mista Bone's Avatar
D Tranny Guru
drill and tap........
Old Aug 5, 2005 | 06:33 PM
EJ1 wilcox's Avatar
Default Re: where to mount the sensor(for water temp gauge on a d16z6) (Mista Bone)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Mista Bone &raquo;</TD></TR><TR><TD CLASS="quote">drill and tap........
This is the only way I would do it... looks stock.
Old Aug 5, 2005 | 07:49 PM
teknoracing's Avatar
Yup thats what i did. And it comes in cool colors like blue red and polished!
Old Aug 5, 2005 | 07:54 PM
mike93eh
Guest
Posts: n/a
this looks identical to mine.
Old Aug 5, 2005 | 08:47 PM
Default Re: where to mount the sensor(for water temp gauge on a d16z6) (mike93eh)
thanks guys, and the pics help alot!!
Old Aug 6, 2005 | 07:21 AM
Scrapin4DR's Avatar
i think i'mma go back to auto zone and get me that 12 dollar gauge and put the bish in there , what gauge was used with that tap in the pic?
Old Aug 6, 2005 | 03:27 PM
Mista Bone's Avatar
D Tranny Guru
Autometer Elec, 1/4" NPT tap and 7/16" drill bit set from Home Depot
Old Aug 6, 2005 | 03:43 PM
CivicSiRX's Avatar
i just tap it into the stock sender. works fine for me for 3 years.
Old Aug 6, 2005 | 05:35 PM
Scrapin4DR's Avatar
Default Re: (CivicSiRX)
i tried tapping it into stock sender and the gauge comes with 3 plugs u plug the gauge in one of those plugs and then u take that plug that comes with the gauge and u plug it in where ur stock sender is going, but in my case 3 different plugs that came with the gauge , none of them would fit my stock sender plug they were too big
Old Aug 6, 2005 | 07:13 PM
CivicSiRX's Avatar
Default Re: (Scrapin4DR)
by tappin into i mean splicin in wit the wire. thats it. problem solve.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Scrapin4DR &raquo;</TD></TR><TR><TD CLASS="quote">i tried tapping it into stock sender and the gauge comes with 3 plugs u plug the gauge in one of those plugs and then u take that plug that comes with the gauge and u plug it in where ur stock sender is going, but in my case 3 different plugs that came with the gauge , none of them would fit my stock sender plug they were too big </TD></TR></TABLE>
