GSR Dizzy questions
a friend of mine has a GSR dizzy that i need for my B16a head. the only thing is that it needs an ignitor installed. obviously, i have an LS motor. can i use the ignitor from the LS dizzy in the GSR dizzy??
is the ignitor from an OBDI+ LS distributor?if so,it will work.
also,have you made sure that the GSR distributor fits the B16 head?i'm thinking that all three tabs won't line up.
Chris
Chris
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by TeamNextGenChris »</TD></TR><TR><TD CLASS="quote">is the ignitor from an OBDI+ LS distributor?if so,it will work.
Chris</TD></TR></TABLE>if its obd-1 im sure it fits. I have a b16 dizzy in my gsr so it should work
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Superdragr45 »</TD></TR><TR><TD CLASS="quote">this is a OBDII dizzy..........both are OBDII</TD></TR></TABLE>ignitor should work. not sure about the dizzy
that's fine too.
Chris
that's fine too.
Chris
racingant
Jun 25, 2005 10:36 PM
