GSR Dizzy questions
a friend of mine has a GSR dizzy that i need for my B16a head. the only thing is that it needs an ignitor installed. obviously, i have an LS motor. can i use the ignitor from the LS dizzy in the GSR dizzy??
Re: GSR Dizzy questions (Superdragr45)
is the ignitor from an OBDI+ LS distributor?if so,it will work.
also,have you made sure that the GSR distributor fits the B16 head?i'm thinking that all three tabs won't line up. Chris |
Re: GSR Dizzy questions (TeamNextGenChris)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by TeamNextGenChris »</TD></TR><TR><TD CLASS="quote">is the ignitor from an OBDI+ LS distributor?if so,it will work.
also,have you made sure that the GSR distributor fits the B16 head?i'm thinking that all three tabs won't line up. Chris</TD></TR></TABLE>if its obd-1 im sure it fits. I have a b16 dizzy in my gsr so it should work https://honda-tech.com/forums/images/smilies/emthup.gif |
Re: GSR Dizzy questions (2FAST4U831)
this is a OBDII dizzy..........both are OBDII
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Superdragr45 »</TD></TR><TR><TD CLASS="quote">this is a OBDII dizzy..........both are OBDII</TD></TR></TABLE>ignitor should work. not sure about the dizzy
dizzy should line up...........we test-fitted a GSR one on the B16a head it all lined up fine......
that's fine too. Chris |
