what kind of amp kit should i get for my amp??
Old Aug 1, 2005 | 11:33 AM
cilvia's Avatar
Default what kind of amp kit should i get for my amp??
i got a infinity 7541a 4 channel amplifier 111x4 rms...what kit would i get?? thanks
Old Aug 1, 2005 | 02:10 PM
gsrjrsc's Avatar
Default Re: what kind of amp kit should i get for my amp?? (cilvia)
buy what ever brand you prefer and buy a kit that will match the largest size of wire that your amp will accept but if you plan to add more amps in the future get over sized wire like 1-0 awg and use a distribution block
Old Aug 1, 2005 | 03:19 PM
fcm's Avatar
fcm
Old Fart
I am no fan of the "every thing you need amp kits" the RCAs a always way to long, and you end up having to "wad" the extra someplace, if you can find the power only kit, get the one with 4x111=444W a 4ga power cable http://www.the12volt.com/wiring/recwirsz.asp and one with an ANL type fuse holder is best. 94
Old Aug 1, 2005 | 05:56 PM
vicn77's Avatar
Default Re: what kind of amp kit should i get for my amp?? (fcm)
agreed ^^^^
don't forget to run your power wire on the opposite side of your speaker/rca wires.
Old Aug 6, 2005 | 11:25 AM
cilvia's Avatar
Default Re: what kind of amp kit should i get for my amp?? (vicn77)
is there any thing against ebay wiring kits?? would it be ok to juss get those 12 dollar, 2100 watt, 4 gauge kits from ebay??
Old Aug 6, 2005 | 07:55 PM
fcm's Avatar
fcm
Old Fart
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by cilvia &raquo;</TD></TR><TR><TD CLASS="quote">is there any thing against ebay wiring kits?? would it be ok to juss get those 12 dollar, 2100 watt, 4 gauge kits from ebay??</TD></TR></TABLE> As long as it's only a power kit, [no RCAs, get them separately] the problem with an "amp kit" is they come with 17' RCA cables, so you end up having to "wad" up a bunch of it, the RCAs should only be as long as the need to be th reach the amp from the HU. a little slack is ok, but any more then 1 foot extra is just to long.
But then again, at $12 you can just get a set the right length and just not use the ones in the kit 94
Old Aug 6, 2005 | 11:59 PM
cilvia's Avatar
other than the long rca cable, is there anything wrong with the quality of the cheap ebay wiring kit wires?? also whats the difference with higher wattage kits and lower ones?? is it bad to get those 2000 watt kits for my 444 watt amp?? cause im thinking about juss getting those cheap 2000 watt kits and buying another rca cable since you said it would be too long...
Old Aug 7, 2005 | 12:11 AM
Xsi's Avatar
Xsi
They are generally not too bad, just be careful to install it properly and buy an rca the right length and it should be fine. (provided you buy the right size power/ground cable for you amp.)
Old Aug 7, 2005 | 12:13 PM
xEnderx's Avatar
Default Re: (Xsi)
I'm running that exact same amp and a 400 RMS 4 channel on a 4 gauge Tsunami kit. I will need bigger wire if I get stronger amps though.
Old Aug 7, 2005 | 05:24 PM
fcm's Avatar
fcm
Old Fart
Most wire sold for automotive stereo systems is TEW wire, [multi strand]
There ar 2 things that make good power wire for car amps OFC [oxygen free copper] wire and lots of strands of it.
The gage of the wire will depend on how much current, [amps] you need to draw through it and how far, or how many watts of power and how far is it from the batt./alt. this chart will help http://www.the12volt.com/info/recwirsz.asp
HINT... the best power/ground wire you can get for your amps is good welding cable
Old Aug 7, 2005 | 08:21 PM
LSDC-4's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by vicn77 &raquo;</TD></TR><TR><TD CLASS="quote">
don't forget to run your power wire on the opposite side of your speaker/rca wires.</TD></TR></TABLE>
i dont know much about wiring and systems, so why is this a problem?
Old Aug 8, 2005 | 03:45 AM
Xsi's Avatar
Xsi
Power cable can create noise if you run it right next to the rca cable. You can use some of the plastic shrouding to cover the power cable to help prevent it.
Old Aug 28, 2005 | 11:11 PM
cilvia's Avatar
Default Re: (Xsi)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Xsi &raquo;</TD></TR><TR><TD CLASS="quote">Power cable can create noise if you run it right next to the rca cable. You can use some of the plastic shrouding to cover the power cable to help prevent it.</TD></TR></TABLE>
bump up for a quick question....does running the speaker wire next to the power cable also create noise?? or is it just the rca cable?? and can i get a example of a plastic surrounding i could use??
Old Aug 29, 2005 | 04:00 PM
cilvia's Avatar
Default Re: (cilvia)
Old Aug 29, 2005 | 04:56 PM
UofLeaderb18's Avatar
On that amp you don't need such a huge kit. (4 guage). If you plan on adding another amp at some point I would go ahead and get a 4 guage kit, if not go with something smaller like 8 guage. It be over kill with the 4 guage unless you plan on adding later on.
Also you could encounter some interference if you run any wires next to your power wires.
Old Aug 29, 2005 | 11:18 PM
cilvia's Avatar
Default Re: (UofLeaderb18)
yea i got myself a 4 gauge allready installed just need to know if its possible to put speaker wire on the same side as the power wire?? thanks
deeboi
Audio / Security / Video
Dec 23, 2012 04:04 PM
XViEtBoiX
Mar 18, 2009 06:07 AM
skrewdriver88
Dec 26, 2005 12:28 PM
pezzy
Sep 15, 2004 09:25 PM
96 Ls lnTeG
12
Sep 10, 2003 02:45 PM
