What suspension in the wake of recent Omni Issues?
Old Aug 1, 2005 | 09:42 AM
k-series's Avatar
Default What suspension in the wake of recent Omni Issues?
I was going to get this setup for the EG I'm working on, but with the few issues I've seen and the close up shots of the thin wall construction, I've had second thoughts.
Would a regular Skunk2 coilover and a set of Koni Sports do the trick or do I look into the Drag Launch kit from Skunk?
(Drag Launch Kit: Honda Civic, CRX, Del Sol 1988-2000 517-05-0730 $349.56 )
Suggestions? (This is for an all motor EG.)
Thanks,
Steve
Old Aug 1, 2005 | 10:04 AM
Boostfed's Avatar
New User
Default Re: What suspension in the wake of recent Omni Issues? (k-series)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by k-series &raquo;</TD></TR><TR><TD CLASS="quote">I was going to get this setup for the EG I'm working on, but with the few issues I've seen and the close up shots of the thin wall construction, I've had second thoughts.
Thanks,
Steve</TD></TR></TABLE>
The issue with the Omni's has been taken care of, they have much thicker collars to provide now in ALuminum or Steel. No worries after these are swapped out or new kits provided with them sir.
Old Aug 1, 2005 | 10:05 AM
k-series's Avatar
Default Re: What suspension in the wake of recent Omni Issues? (Boostfed.com)
How will I know if I'm getting the newer kit? Should I order from Omni directly?
Steve
Old Aug 1, 2005 | 10:10 AM
Boostfed's Avatar
New User
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by k-series &raquo;</TD></TR><TR><TD CLASS="quote">How will I know if I'm getting the newer kit? Should I order from Omni directly?
No all the ones going out now will be revised and have the newer collars on them, no worries. I get mine straight from Omni so they will be updated, if you buy elsewhere just ask them
Old Aug 1, 2005 | 03:15 PM
SuperTeg95's Avatar
are they swapping them out for free or whats the deal? mine are 4 months old so they are probably the old ones.
DelSolMike
Oct 22, 2013 09:27 PM
Mel 1320
Mar 13, 2010 02:26 PM
Sean18337
Nov 6, 2005 04:27 PM
hybridgs
Suspension & Brakes
Sep 28, 2005 01:29 PM
SoCaLNaTIvE
Aug 15, 2003 03:25 AM
