Clutch Advise
Old Aug 1, 2005 | 06:53 AM
typer_696's Avatar
Default Clutch Advise
Hey you guys I need some advise on a clutch kit. I am planning on buying on Exedy clutch. Is it worth buying has anyone had problems with it and does it last long or should I spend the extra money and buy an ACT clutch.
Old Aug 1, 2005 | 08:16 AM
RagingAngel's Avatar
Default Re: Clutch Advise (typer_696)
On the upper right, click Search.
Then you enter "Exedy"
Select archived
Then select "Integra Type-R" as the forum and hit enter
WALLA!!
» Search Results
Your search for Exedy returned 70 results.
Enjoy
Old Aug 1, 2005 | 08:40 AM
Azcheron's Avatar
Default Re: Clutch Advise (RagingAngel)
Action
the only clutch company
Old Aug 1, 2005 | 09:34 AM
Bbasso's Avatar
<--- uses ACT clutch, and like it.
Old Aug 1, 2005 | 10:11 AM
LUCKY CHARMS's Avatar
i've been using exedy 3 puc & flywheel for 12 months with no complaints, time for a new one, anyone know what the story is with RPS 6 puc??was told its a bit easier in traffic
Old Aug 1, 2005 | 10:38 AM
Chris F's Avatar
Default Re: Clutch Advise (Azcheron)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Azcheron &raquo;</TD></TR><TR><TD CLASS="quote">Action
the only clutch company</TD></TR></TABLE>
I hated the 1MD. 2MD is much nicer, which seems odd to me because they're the same besided the pressure plate... it could also be that I got a new flywheel at the same time as the 2MD. Both will get jerky if you don't give them enough gas when taking off in 1st.
-Chris
TypeSFTW
16
Mar 13, 2008 05:50 PM
globy123
Nov 29, 2007 11:21 AM
MachinaInfernus
Feb 24, 2007 07:34 PM
JDM_EH2
Sep 10, 2005 11:34 PM
tech6804
Oct 2, 2004 08:26 AM
