TSX/Type S Hybrid into EG. Almost done, One Question for you rsx guys.
Hey,
So this weekened we mated the tsx motor to the type S tranny. If you look at where it meets on the bottom side you can actually see the flywheel. It's exposed to the elements. Is there an inspection plate or something I'm missing?
Thanks.
Thanks.
Ok, I found my answer but I need further help.
Part number 1 is what I'm talking about, the clutch case. The RSX/TSX clutch cases have differnet pn#'s so I still need to figure out which one to use.
Here, you can seee that it will bolt up to the bottom of the tranny casing as well as that top bolt in the pic which goes to the block:
Now, could one of you type s rsx guys look under your car and see if the holes are in the same position? That way, I'll know I need a type S one.
Thanks!!
Thanks!!
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by TYPERman2001 »</TD></TR><TR><TD CLASS="quote">i have a type s clutch shield cover make an offer on it</TD></TR></TABLE>It's $14 off acura. I already ordered one.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by BlueIntegraBoy »</TD></TR><TR><TD CLASS="quote">Will it be running this week George?</TD></TR></TABLE>It should've been running on sunday. I thought i could wire up a pnp harness but can't, so i'll need to order one. I also need a new vtc sensor cause mine broke during shipping. I'm just waiting for parts now...
check this out: https://honda-tech.com/zerothread?id=1327344
that thing is going to be a beast mated to that tranny in an EG that sounds like something.... i always wanted to put an f22 or f23 in an EG so much low end tq and theyre a dime a dozen you could boost the hell out of em an it wouldnt matter
Hey litterbox, where'd you find that piece on the website? I actually need it to, but can't find the damn thing in any of the pics for RSX parts.
EDIT: NM, found it, the pic just doesn't look anything like it is in real life.
Derfology
11
Sep 25, 2005 09:54 AM
