Y80 tranny...is it LS or GSR?
It seens very confusing about Y80 hydro tranny. On web sit like http://www.ff-squad.com showing Y80 hydro tranny list as US94+GSR, but my 94 LS come with Y80 hydro tranny.
So which one is which? Need help to clarify!!!
thank you!!!!
thank you!!!!
Both have Y80 imprinted on it. The only way to find out is the gear test. In 5th gear at 75 MPH, you should be at ~3250RPM in an LS and something like 4500RPM@75MPH in a GSR. Its a big difference.
by my calculations with stock tires GSR should be at 4000rpm at 75mph and LS is at 3500rpm. keep in mind that the stock tachometer will read a couple hundred too high at that point, so i can understand if your ITR says 4200 at 75mph. also the stock speedometer will read a tad high, but should be almost unnoticeable at that speed. the tachometers are a lot worse about that than the speedometers IMO.
tegasaurus
Feb 5, 2007 07:29 PM
integraautox
Sep 30, 2003 11:24 PM
