what are your opinions of a clutchmasters stage 3 on a turbo car
Old Jul 31, 2005 | 09:45 PM
alexsracing's Avatar
Default what are your opinions of a clutchmasters stage 3 on a turbo car
what are your opinions of a clutchmasters stage 3 the segmented kevlar on a turbo car?
at 12 psi or higher
does it hold well?
Old Jul 31, 2005 | 10:21 PM
abnaasefmb's Avatar
Default Re: what are your opinions of a clutchmasters stage 3 on a turbo car (alexsracing)
bump cuz i got one waiting to go on.
Old Aug 1, 2005 | 05:27 AM
non-VTEC's Avatar
im running the CM stg3. so far its been under 11psi nothing more but it holds really well.
it all depends how much power you plan on pushing through it. i think if its under 400whp it should be alright......anything more you might want the stg 4.....
Old Aug 1, 2005 | 06:58 AM
tthame1's Avatar
Default Re: what are your opinions of a clutchmasters stage 3 on a turbo car (non-VTEC)
What kind of power are you planning on making? That will decide the clutch. I'd say if its under 350 whp, then you should be able to use a stage 3. The stage 3 is much more driver friendly that the stage 4, so if at all possible, use the stage 3. I'd personally recommend a Competition Clutch vs Clutchmasters. Competition Clutch uses a slightly different material than CM and it doesn't heat up and slip as the CM will after consecutive passes. Also, the CC requires no break in and its much cheaper. I got an awesome deal on mine a while back from Lightning Motorsports (Lightning on here)
Old Aug 1, 2005 | 07:14 AM
its because mine is slipping at 11-16 psi but at 7-8 or less it kinda holds.
Old Aug 1, 2005 | 07:36 AM
tthame1's Avatar
Default Re: (alexsracing)
Are you making consecutive passes? Mine used to slip if I made more than one pass without letting it cool down.
How many miles are on it?
Old Aug 1, 2005 | 09:58 AM
Finland's Avatar
I've had mine for over 3 years, with well over 100 passes on it and over 30K miles. I love the clutch.
Remember that you should get the least clutch that you need to get by, don't over clutch the car, you'll be miserable. If you are building some wicked torque monster, that's track only, then you might want something stronger, but for me it's been great.
Old Aug 1, 2005 | 11:37 AM
SHystrdyGSRtdy's Avatar
Default Re: what are your opinions of a clutchmasters stage 3 on a turbo car (Boondock Saint)
clutchmasters stage 4 @ 341whp https://honda-tech.com/zerothread?id=1322037
Old Aug 1, 2005 | 11:42 AM
tthame1's Avatar
Default Re: what are your opinions of a clutchmasters stage 3 on a turbo car (SHystrdyGSRtdy)
IDK, I'm currently running a Competition Clutch Stage 4 with absolutely no problems pushing 415 whp. Its a little harsh, but its not too bad for the most part.
tgreaves's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by alexsracing &raquo;</TD></TR><TR><TD CLASS="quote">what are your opinions of a clutchmasters stage 3 the segmented kevlar on a turbo car?
at 12 psi or higher
does it hold well?</TD></TR></TABLE>
psi has nothing to do with it.. its about how much torque your putting out that determines what clutch you need..
Old Aug 1, 2005 | 11:45 AM
B16Civic93's Avatar
Default Re: what are your opinions of a clutchmasters stage 3 on a turbo car (tgreaves)
i have a clutchmaster stage 3 on my turbo b16 and it holds fine (knocks on wood)
i hope that it will be fine with my turbo ls/vtec setup that is going in soon...
Chipped B6
16
Feb 24, 2009 09:11 AM
TSX TEX
Mar 19, 2006 09:32 PM
BLKCivicPorscheStyle*
Apr 5, 2005 11:56 AM
legendboy
Jul 16, 2002 12:06 AM
